piston ring filling
MILLENNIUM FALCON
Over 1,000 Posts
DTT BOTM WINNER
I have heard of people grinding the ring gap on oversized rings to make them fit in a std. bore. Is this true? Does this cause any problems? The reason I ask is because it seems no one makes std. rings for Kz400's anymore. Oversized rings are common on ebay. thanks.
If I'm not mistaken, that would make the ring slightly egg shaped when in the cylinder. Right?
It's a standard proceedure to measure the end gap on new rings in the bore and trim them to spec.
If you can't get standard rings, you're not going to have much choice anyway but to use oversize (or get oversize pistons and re-bore....$$$).
1st oversize is usually 25 thou, which is pretty small in relation to the bore size, so it's unlikely they will sit oval in the bore.
1st oversize is 0.25 Millimeters (quarter mm) or, about 0.010" (ten thou)
Main problem would be chrome cracking off edges on top and oil rings.
Will also need a relatively 'rough' hone so they will bed in properly
I would find some oversize pistons and bore it (EX500? ;D )
Talk to your friendly neighboorhood engine builder, typically they can find rings and or modify the pistons to fit something close. when i first talked to my builder he was gonna use some rings meant for some oddball british car, but then i managed to find STD rings,
I got a set of first over rings (.25) for my bike since all the replacement parts I got needed a hone to remove the glaze and then put back together. I hand filed the rings to fit and the bike runs fine. Like PJ says make sure you hone well so they will seat correctly. They make grinders that will size them for you but the cost of a ONE for the job was way out there for me. Just got a Coors Light and a hand file and went to town, took a little over an hour.
Engine has about 500-600 miles on it since I did it and man does she pull, was hauling ass around yesterday and noticed she accelerated right up a hill past 70 in 6th when I normally had to down shift and maybe get 60 up it.
