Okay so my 1976 CB550 runs great when accelerating but after its warm the idle tends to hang at 2k and then eventually drop. I think the issue is because I moved the needles up one notch because I thought it was sluggish in low rpm acceleration. Im guessing moving the needles back down will fix this issue.
My other issue, is Cylinder 1&2 blow cool air at idle, where cylinders 3&4 blow hot air. I know that 1&2 are getting spark and firing because i checked spark and the headers get decently warm, no where near as hot as 3&4 tho.
Other info:
Carbs rebuilt with 4 rebuild kits
Float heights checked
All bowls getting fuel
New points and condensers
Timing set
Valves checked and adjusted
Spark plugs look black with some build up (they were new), not a plug chop at WOT, just after pulling them and looking at them
Here are my two vacuum videos. I only have a vacuum reader for a twin, so i did each side individually, not sure if that allowed or not haha.
Cylinders 1&2....the ones that blow colder air
http://www.youtube.com/watch?v=f2z3wZZQQzI
Cylinders 3&4....in my opinion the better running side
http://www.youtube.com/watch?v=2CojkYDn1KI
Other info:
Timing set
