Tune-A-Fish said:Im running 105/35 1.5 out 3rd position up and things seem right, but I keep looking for a lean condition nothing yet but I run gas no corn.
Loctite77 said:That is definitely way leaner than what I currently have. Is the bike stock? That sounds like about stick settings.
Yeah Son!
Yeah Son!
redwillissuperman said:Loctite77 - your bike is stock. The little muffler and pods are done nothing. Take the carbs completely off and go through each passage with a thin gauge wire. Put in stock stuff. Verify your manifolds are sealing. Go back to factory settings and get it to run correctly. A 750 should "zing" to redline not sound like an old Russian tractor.
Verify that you have the right combination of resistor plugs and wires. What ohm coils are you running?
teazer said:Raising the needle will make it way too rich mid range as long as the main jet is too small. I know that the plugs read rich, but try a larger main jet and keep going up until the 3/4 to WFO is right and put the needle back in the middle slot to start with. You may need to change needles later or get custom needle jets made. Honda used 2.6mm jets in almost all their bikes for years and changed the needle root diameter to moderate fuel flow.
IIRC there were a few different CB750 needles over the years. Not sure if I have any left from the experiments where we tried to get a CB77 to run cleanly on methanol (it did) and went through a few different needles before I "machined" them to a different taper.
Fair enough, but this is the first time it's been addressed after three pages of advice. Also, motorcycles don't get nearly as hot as a V8 and don't do nearly the job at cleaning them. So, they really don't clean even at WOT since they barely get above 400° iirc. Carbon burns off at above 550°. Also, the rpm at idle mix needs to be addressed as it could be causing a false rich condition.teazer said:I have to politely and respectfully disagree. The ONLY time that a plug chop is useful in terms of fine tuning mixture is wide open under load. At anything less that WOT, the plug temps are much lower and often below the temperature at which they self clean and therefore very misleading.
A plug running cool at part throttle should look as if it's running rich - not because it's rich, but because it's too cool to self clean.
