Plug made from clay, whats the next step?
Boarderx192
Ive been working on a new seat shape for my GS1K cafe. I have it modeled out of clay right now and Im ready to start the next step. Whats the best way to cover the clay? I was thinking:
Mask the entire seat.
Cover the masking with aluminum foil tape
Few layers of wax on top of the foil
Start laying some fiberglass
The plan is to use the clay plug to make a quick mold. Then Im going to coat the inside with the aluminum tape, wax, and lay some fiberglass cloth to get a fiberglass version of the clay mold so I can keep the proportions that I have right now and just clean it up with some bondo and then make a final mold.
Does that sound about right? Suggestions?
When you're happy with the shape, wax thoroughly - or spray with release agent and then take the master mould directly off the clay. At this stage what you end up, is what you will get ad infinitum!
No need to build up as any product you take out of the master mould will be identical to your clay. ;)
If you are taking more than one product out of the mould, make sure you make the outside of the mould rigid - cardboard tube is ideal for this. This will keep the shape and stop the Master [ "King" ] mould from warping. Make the mould at least 3 times heavier than the product if you are taking multiples.
If you have "reverse" shapes, ensure that you will be able to remove the product from the mould ! 8)
Just to give you encouragement - the attached was modified using the same process !
We took the basic RAM Cobra bodyshell and sculpted all the additional scoops, vents, etc. by the same method, and the planted on / in the mods before taking a new mould of the whole car.
The car is the prototype RAM SC [Super Cobra] primarily aimed at the track day market.
No, we use diamond cutters and routers on air tools - much more precise and leaves a better edge to the GRP.
The body shown had a whole range of scoops, vents, etc. and then we made split moulds so that a customer could mix and match for their own preferences.
