pod filter effects
loudest143
Insert sense of humor here---->
Hey, I've got a question about what happens after you install pod filters... I've read all the information about installing, rejetting, and performance gains/losses, I'm simply interested in one thing. How tempermental does a bike get after going to pods and free flow exhaust? I've had a couple of buddies that went back to stock filters, saying it was too much trouble to keep the bike running consistantly well.
To me, this sounds like the bike wasn't tuned well with the pods well in the first place. THust thought I'd throw this one out and see what you guys have to say on the topic.
loudest143
lot depends on bike.
First thing, they dont lean out low end, the stock airbox isn't restrictive at low rpm so base jetting doesn't need changing, unless you switch exhaust at same time.
Usually the mid range gets very rich because tuned induction length has changed plus air flow is completely different in transition phases (the main jets are usually too large to make sure it doesnt lean out at max rpm)
Top end will always be lean with stock jetting, sometimes not much, sometimes enough to burn valves and pistons.
Its also very dependant on exhaust system fitted, free flowing short loud system needs richer jetting but can still lean off at certain rpm.
You can make almost any combination work, making it work properly take time and effort
PJ
If you set the bike up correctly, theres no reason it cant be just as reliable as stock. Ive found that most folks who build a bike than complain about how tough it is to keep it running right, or maintain it, cut corners and didnt set it up correctly in the first place. Guys run these bikes on the track (with pods or unis and open exhaust) all day with no issues.
Thanks for the good points here. This is always a great place to get advice without the guilt!
I should have mentioned my bike. 82 suzuki gs850g. I've installed a Mac 4 into 1 (which I got for a song) and a Muzzy cannister (which I got for 15 bucks, and repacked it for 10!). The only issue I had with the bike after the exhaust installation was hard starting. No big suprise, really. I've installed new pilot jets, and like a dope, went ahead and installed new main jets, up one size from stock. I'm going to pull them out again and remove the bigger main, as I'm still with the stock airbox. My starting issue went away, but my plugs were black as night. Back to the original main jet I go, until I can get pod filters.
Of course, if I drag my feet enough, I can leave in the bigger mains and just get the pods, and I'll be close.
PJ, you commented that pods will richen the midrange circuit? So with your advice, I should drop my needle lower one click. I am a bit confused by this, as I thought the pods would ADD more air. This may be a misconception on my part.
Again, thanks to all who replied.
loudest143
I have pods on my KZ650 and the bike runs excellent through all the RPM range....except when I get a crosswind. Riding on a windy day can be a real pain. Normal cruising around town is no big deal but if I get up to highway speed when its windy you can feel the bike surging, like someone has a string on the back of the bike and is pulling it. Other than that though I love them. I don't do enough of that kind of riding for it to really bother me.
They make removing the carbs very easy too.
Ive seen a pic of a cb175 racer that has two small pieces of plexiglass, maybe 1.5" high x 3" long attached to the outsides of the filters to cure that issue... ill see if i can find the pic. It was a pretty cool setup.
loudest143
Yep, drop the needles
If it helps, my 850 came with a 4-1 and I've also fitted pods. Just getting it to rev properly saw me go from the stock 115 mains to 125's on the first try. That wasn't quite rich enough after 7k so I ended up fitting 130's, which seem fine up to redline and even a little bit past.
It starts perfectly first hit of the starter every time and I haven't touched anything else apart from the air screws, which will always be an individual setting. I'm telling you now, the sound with this setup is insane...and probably well over the legal limit of noise output at the hgher rpm's. Good thing they only test at half of redline here, hey? 8)
Cheers - boingk
Boingk, you've got stock 40 pilots and then 130 mains with the pods and 4 into 1? Well, it seems I've attacked this wrong way round. I'll pick up some bigger mains along with the pods.
I secretly like working on carbs. As an electronics tech, the electrical system on this bike has just worn me out. I'm liking the full mechanical aspect of the carb, even if it does require a good bit of finess and experimentation.
loudest143
loudest143
Dunno why?
its a a really simple permanent magnet 3 phase alternator/generator with 3 phase rectifier and voltage regulator.
Can't get much simpler. (single phase/ half wave rectifier as on 100/125?)
If you had early GSXR, Katana or Bandit with 3 phase center tap alternator (Suzuki call it 4 phase, but its not ;D) plus digital TPI ignition, it would be a bit more complicated
PJ
crazypj said:
Dunno why?
PJ
I likesez you purty talkin'. :P
I guess I know who I'll annoy when I get to the electrics.
I still have the side covers on my bike until I relocate the battery and electrics so you can't even see the pods. I would bet that a side wind would effect you once opened right up.. The plexy sounds like a nice way to show off the pods and have an open look without the wind/rain issue during cross winds. No matter what it got rid of the horiible huge air box.
Cheers,
Yeah, I'm a fan as well. Its like a mechanical computer for fuel injection, and you can actually change the way it runs! Always loved the simpler technology thats been applied over the years, I mean people go on about putting chips into ECU's to give a boost...well we just mess the timing around and jet the carbs, all for about $3 a jet.
Anywho, your mainjet is always the first stop on a bike thats been modified. After that its the needle height (best thought of as fine tuning the main) and then you can mess with float height if you really want to - the aim with all these is to give best high rpm pull, best midrange response and best acceptance of full-throttle, respectively. Of course, adjust the airscrews to suit the new mainjet before you take it for a spin.
As for airboxes, if you ever get a look at an Aprilia RS125's airbox you'll see what good 'box design looks like. Brilliant bit of kit, makes the one that came with the GS's look like a crude attempt put together by a foreign hobo. Hence the pods.
Cheers - boingk
