E eran_k Been Around the Block May 1, 2013 #1 If my carb intake size is 50mm (OD) do i need 50mm pods or a tad smaller? thanks Eran
cqyqte Grumpy retired oldtimer... "eat a Snickers bar" May 1, 2013 #2 50mm will be correct, as they come with a band/spiral clamp to tighten them onto the carb horn.
Brodie Gold Coast, Queensland DTT SUPPORTER May 1, 2013 #3 Check out this thread if you have not already. http://www.dotheton.com/forum/index.php?topic=45863.0 I just spent some time sorting a carb problem only for it to be the airfilter.
VonYinzer Over 10,000 Posts May 1, 2013 #4 As stated in the above thread... DONT BUY CHEAP SHITTY PODS. Spend the money for a quality product. Otherwise you're just setting yourself up to fail.
Rich Ard doin' the backstroke in an estrogen ocean DTT BOTM WINNER May 1, 2013 #6 Re: Re: Pod filter size eran_k said: Whats considered good quality other then k&n? Click to expand... UNI; also, MikesXS sells a k&N knockoff that i've heard is good to (but haven't used myself).
