Might be useful to know what bike you are talking about.
Typically, this is how you do it, but then you tweak the point gap of the second set of points to get the second cylinder timing spot on after you have the first cylinder gapped and timed. The point gap of the second set might be a couple thou one way or the other to get the timing right.
I don't pay attention to gap measure when setting points. What's important for static timing is when the points open, it needs to be at the exact moment when the idle timing marks line up at the crank.
If the gaps are too large or too small the engine will misfire. I have a 75 360 and I set the timing then check the gaps. If the gaps are outta spec, set em then go back and do the timing. Check the gaps again a repeat the process until timing and gaps correct.
It's important that the gap be within the specified range. This is from memory, but I think correct:
Nominal gap is 0.014". Set the points to that. Then set timing on (I think) left cylinder. (Front point set.) Timing on left cylinder is set by rotating point mount plate. Then the right cylinder points timing is set by tweaking the point gap. It should be +-0.002" from the nominal gap.
I think I got it everything is dialed in.The light goes on when it should.Thanks for all your help,Im gonna try to start it monday if my tank is done.First time in 25 years,SAY A PRAYER.
ADC is right, points gap on all the Japanese bikes I've worked on for last 40 yrs are 0.012" to 0.016" with 0.014" being 'ideal'
Larger gaps mean coils don't have time to 'charge up' smaller gaps don't 'break' clean and usually burn surfaces real quick
My gas tank wont be done til fri,so i filled the bowls up and gave it a shot.I couldn t believe it started on the 2nd try.Now I need to make a battery box.Thanks for all the help,the bike seemed to be timed great.
