xb33bsa said:dude with the mystery oil is no too smart :,all he is doing is making a slurry in his process then using it to totally fuk the chrome forever
you may as well just mix dirt and sand with atf and go after your chrome from there and what you get is chrome scratched up beyond fuckhead repairing
as far as alloy polishing with dirt mixed with atf that would be the perfect process for you have at it report results,number 2 potting soil is best
Hoosier Daddy said:Maybe I am just a little touchy this moning but DUDE... use the Search button here on DTT!
This has been covered many, many times. There are excellent "How to" threads can be found here on this very topic with just a couple clicks of the mouse. I've written a few posts in them myself. So much info, tips, and alternatives that they can't all be rehashed in this thread.
A.D.'s answer is the just of it, but if you don't have a bead blaster don't let that stop you. The first couple I did I didn't have one. I then built a D.I.Y. blasting cabinet from threads I searched and found here... You can start out with 80-120g sandpaper... work down to 800g or finer... pick up a bench top buffer and compound and have at it.
... Oh and lastly, get a grease zert installed in your elbow.![]()
i was pointing out that the guy was using DIRT to polish his chrome ;D ??? :edelweiss said:I don't plan on using it on chrome, but are you saying it will screw the aluminum up too? I know, sounds like a dumb question seeing that aluminum is so soft. Is it like the oxidation that is coming off then acts like an abrasive as he is wiping it around?
Hoosier Daddy said:Start here... It's even a "sticky" Polishing 101![]()
Hoosier Daddy said:... Oh and lastly, get a grease zert installed in your elbow.![]()
Hoosier Daddy said:
