polishing alumunim
caseyjk
I need some tips for polishing. What should I use to clean the aluminum and polish it? I have a 6in grinder. Theirs heavy white rust on everything?
Casey, that is oxidation, aluminum does not rust. However, it still needs to be removed. As far as the 6in grinder goes, well you won’t need that until you get to the buffing stage, and it sounds like you are a ways out from there.
Start sanding the part with sandpaper. If you oxidation is heavy and has pits, then you may want to start with 220 grit. Using the 220, sand it until it is smooth and has no visible oxidation. Once you have that, step up to 330 grit and sand all of the 220 grit marking out sanding in one direction the entire time. Next step up to 400 and wet sand it in the same direction, then on to 600 grit wet in the same direction. Now move on to you sewn buffing wheel and some red or brown rue. Polish the part running the wheel in the same direction you have sanded and applying light pressure. Once a nice even polish is on the part clean the part with some acetone and swap your wheel out to an un-sewn wheel and some white rue. Buff the part down using medium pressure over the entire part two or three times. Now go over it two to three more times using light pressure. Remember that all of the polishing and sanding should be done in the same direction. Once you are done, clean with acetone followed by hot soapy water. DONE!
Some stuff I have done with that method:
save yourself the time.
sandblast, then hit everything with 400 grit GREASESLESS COMPOUND. that stuff is GODLY.
then after that use sisal wheel with emory rouge, then sown wheel with tripoli rouge, then finish with white rouge on a unsown cotton buff.
this has been answer 50 times. search the site.
all you need is practice. a LOT of practice. a couple hundred hours, and youll learn what works and what doesnt. then youll look back at your old parts and say "hmm, thats not polished; its just shiny"
