I'm new to the forum, but old to polishing. I'm a goldsmith in real life so I spend way too much time making things shiny. Here is the rundown from my experience:
There are two things you want to keep in mind when you choose a polishing compound. First, how fine or coarse it is, and second how hard or soft it is. There is a huge difference in putting a polish on materials like stainless and aluminum, and the right choice of compound is critical. The easiest, most complete selection that I have found is from Caswell, either in the US or Canada. You can get things cheaper from Gesswein, but it will be more grief- I think you have to set up an account, etc. and the Canadian office often doesn't have stock on hand.
With stainless, I use the black compound that Caswell sells, and then finish with white rouge (which is chromium oxide) If things are really scratched I use a beartex wheel (frfom Gessweinn), but it will not get into small spots, and it takes some practice or you will leave an uneven surface. They are expensive and hard to balance, but they last me a couple of years of regular use. This is what I use to polish the little code numbers off the tops of bolts before I use compound.
For aluminum, I usually start with triploli. Get the beige stuff, it sticks to the buff better and there is less airborne. I finish with either green or red rouge. Use a separate wheel for each compound and mark them with a Sharpie. It will be hard to tell after a few hours of work what is what.
The wheels themselves are important too. Hard muslin is great for most steel- they are usually yellow in colour. Regular white cotton buffs are better for finishing and most aluminum work. Try to use the largest wheel that you can for the size of the piece and the power of your polishing motor. If you use a wheel that is two inches larger, you are adding another six inches on each rotation. This will keep your time and effort at a minimum and give you a more even surface too. If you find it is leaving greasy spots on the piece, try adding more compound- It seems opposite to what you would expect, but it usually works.
Now the problems. Polishing aluminum castings is the definition of insanity. I keep doing it over and over and expecting a different result. The problems you are going to see will look like small pits or even extremely fine veins. These are all just under the surface skin of the metal in the casting itself, and the more you work at them, the worse they will get. Accept them, try not to be irritated by them, and move on as soon as they appear. I really mean this. They Will Get Worse. Put the best shine you can on the piece, take out the worst scratches and get over it. I have not had good results from regular steel either. For chrome plating, I usually try to get a smooth, even surface and then I really have a serious go once the copper layer is on. Copper comes up mighty fine with little effort and the extra time you would put into the steel is not important. Stainless is pretty when it is done, and the aluminum always looks wonderful if you step back a few feet.
Another thing. Almost all of the castings will have some sort of clear coat on them. You can burn through it with the wheel, but it will take a really - long - time. Take a minute to apply a layer of paint stripper, or you can use gasket remover, and you will find that most of the scratches were in the clear coat, not the metal. Just remember to remove the stripper with a SOFT brush. A wire wheel or a hard brush will apply scratches to an otherwise good surface. Just go straight to rouge, and you'll be done in time to watch the hockey game (unless you live in Toronto).
Now the warnings. First keep fingers outside of all small objects. If the piece catches in the wheel it is better for it to go flying rather than you. I have seen a baby finger do two complete rotations and remain attached. Think of that when you pick up the little brackets.
The most common injury is burns. Aluminum gets very hot, and it stays hot for a long time. It is the frying pan- you are the bacon. Heavy gloves are a good idea, but I don't like the loss of sensation, so I work on a buch of things at the same time, and switch them up as they get hot.
Airborne particles vary by compound. The safest compounds use carborundum and other inert abrasives, but things like chromium dust are not good for your lifespan. Even a basic mask is worth the effort.
Eye protection is for sissies. I would rather spend the afternoon in the ER waiting room watching the Dr. Phil rerun about "Stupid People Who Do Stupid Things"
I did almost all of the shiny stuff on an XS650 in a very long weekend. It hardly seemed worth it until I compared it with the "before" picture. Use light pressure to start, and don't be concerned about all the dust flying off the new buffs. It will stop as soon as they are all charged up with compound.
Play Safe---Rick
