180 is way too agressive of a grit to start with!!! If you start that agressive, your finer sanding will take much longer as you will have to sand out all the grooves created by the 180 grit sanding. 300 to 400 grit is a good area to start. After achiving a good even tone on the entire surface using the 300 - 400, start stepping up in grit, move up to 600, then 900, then 1200, then 1500. When you get to the 900 grit and higher, you will want to wet sand, and make sure you rinse often. Once you have gotten a good smooth look with the 1500, get on the bench grinder with a polishing kit. You can get a decent polishing kit at harbor freight for like $25-30. It comes with all you need to finsh the bling on that aluminum! Once your done, shoot some good clear over it to protect it.
As far as polishing with the kit on the bench grinder, the kit comes with step by step instructions and a guide to what polishing rues to use on what type of surface.
