Poor Idle / Backfires
foto4peter
Hi All!
I'm trying to understand and put together a list of all the possible causes for why my bike is backfiring.
1980 Honda CM400T
I've cleaned the carbs several times. Everything on the bike is stock meaning that the airbox is still in and no jet kits have been added. Air filter is new and the rubber boots on both ends are in great shape. Also adjustment screws are at factory req. - 2 turns out.
What I'm experiencing is at around 3700-4000 rpms while decelerating (overrun is the term I believe, correct?) the bike backfires. Occasionally it will backfire at idle and/or during start-up. I also noticed that once and awhile it backfires in the carb.
I tried spraying carb cleaner around the boot clamps, gasket and exhaust clamp areas to see if the rpms change, nothing noticeable.
From what I have read online I should be checking the following:
* Valve clearance
* Carbs "pushed" in all the way with the boots - mounted on heads
* Rings - may be damaged
* Replace pilot jet with a larger one
* Raise jet needle a notch or two
* Synch carbs
* Exhaust leak
* Air leak - manifold
* Air cut valves may be damaged (appears fine)
What am I missing?
I'm trying to learn how to do these things but unfortunately I don't have the required tools for all these checks and can't financially afford to get them either at this point.
It may have to go to the shop but I'd like to do what I can before I send it in and find out it was something stupid I should have noticed.
Here's an update to the situation...
I did some parts replacing on the carb:
new accel pump assembly
new aircut off diaphragms
new float bowl gaskets
and another good cleaning (soaked it over night)
The bike runs "better" but it is having problems at idle and starting off in 1st gear.
Usually takes several attempts to start and when I'm riding, come to a stop and start off in first the bike losses "power" which usually causes it to die. When I restart it it will take several attempts and usually backfires. The rpms "bounce" +/-500 until it either dies or I use the choke to hold it around 3000 rpms. If I hold the choke at 3000 then it will run fine.
I hope I've stated this clearly, any help is greatly appreciated.
I read somewhere that turning the pilot screw out a full turn or two could help.
Is this possible?
And if so which? I ask which because on these carbs there are two screw-able pieces in the pilot jet "area".
What about the floats? Are they within spec as well?
This is a tough one...... If you think adjusting the mixture screws will help, try it. Can't hurt, right?
Without being there, all the classic signals of it being lean are there:
1) Unwillingness to accept throttle
2) cracking/popping/backfiring
3) runs better with choke
So, I'd first try upping your needle and see if it helps. If it does, you most likely need to run a larger mainjet.
If it doesn't, you may need to lower the float height so slightly more fuel fills the chamber. Try playing with the mixture/air screws first of course, I always find its beneficial to do this after any strip down or modification to find what settings it runs best at. After all, stock was what it came with 30 years ago or more...everythings changed since then, right down to fuel octane and lead content.
Cheers - boingk
PS: Check my 'Tuning' thread here as well for some background on carby tuning.
My initial reaction is either youre running rich or lean, tending towards lean because you say its backfiring out of the carb. The stock carb settings are guides to help you get within the range for the carb settings, not the absolute rule you must follow. When the bike came from factory, everything in the carb was brand new, perfectly sized jets, needle with no wear, none of the rubber breaking down at all. Now that its been run for 30 years, peices get worn down and change the clearances. Id work on getting the carbs dialed in perfectly.
With that said, usually i run down this list on a bike when i buy it:
1) Set/check timing
2) Adjust valve clearances
3) Set carbs
If the timing and the valve clearances arent set properly, you can most likely get the bike to run well, but its no good for it. Its also easier if you get everything else set properly first so you can be sure your carbs are in sync and set correctly.
If everything is stock on the bike I wouldn't go changing jets sizes or needle positions. These are setup from the factory for your bike with the stock equipment and, if there are issues, changing these will only be a band-aid for the actual issue. I would remove the carbs though and ensure the idle circuit is totally clean and clear.
Also, the carb floats in the 400 are the plastic non-adjustable one so you won't need to set the height on them, but you should check to see if they are leaking (i.e. filling with fuel) or are sticking somehow. I'd definitely check the valve clearances. Really easy to do on the 400 and doesn't require any special tools. Even if they are not the issue, it will help eliminate this from your list. Adjust cam chain tension as well.
Timing on the 400's is non-adjustable so I'm thinking timing is not really the issue, at least I'd check the other things first. Are you getting a good spark?
I'd also look for exhaust leaks these can lead to backfiring like you describe.
Air cut valves are stuck.
They are on side of carb and designed to prevent afterfire on deceleration
I've posted about them a couple of times
thanks to everyone for chiming in, much appreciated!!
boingk - float heights are not adjustable on these orginal floats, all plastic which by the way are in very good condition (no leaking)
I've played around with the mixture/air screw, factory setting is 2 turns out, I tried 3, 3.5 and 4 turns out and no difference...
bob - timing on these bikes does not exist, all controled through the CDI unit
I do need to check the valve clearance though, need to read up on this first and make sure I have all the needed tools
to sync the carbs I need to bring in it but the only guy around here isn't available until the 23rd, so trying to do what I can before this
spark appears to be good
crazypj - air cut off valves have been replaced along with the accel diaphragm
That plug looks a bit lean but i cant really tell. Is that ash on the top more whitish or brownish? The mix screws must have been doing something though, sometimes its really really hard to hear the difference, you need to get your ear right up to the cylinder and listen really hard. A full turn is way too much though, even a half turn is. Do 1/8th turns or even 1/16th turns once you get closer, and give it about 5 or 10 seconds between turns. Also if you have the manual it will tell you which way is richer and which way is leaner. Not sure about the carbs on your bike but id bet that counter clockwise on the mix is richer. Make sure youre doing it with the bike warmed up too, no choke.
You can also make your own carb sync gauge for about 30 or 40 dollars (a quart of 2 stroke oil, some zip ties, a yard stick, and 25 feet of pvc tubing, plus the adaptors from motion pro are about 15-25 dollars if you need them). Its a handy tool to have.
Looks pretty lean.
I would check pilot jets and burnish them with a strand of copper wire.
Check float height is set correctly, I don't remember them being all plastic without a metal tang? (but it was a long time ago)
original carbs have fuel screws, unscrew is richer, more than 3 turns needs larger pilot jet (I think we used to run them about 2.75~3turns out)
well... I took it to the extreme - I removed the pilot jet (testing purposes) and it starts right up and doesn't backfire
but as you would expect it's too rich! try to give it gas or adjust the choke and it dies.
so unless I'm mistaken I need to increase the jet size however I'm not sure by how much..? or where I can purchase them online. anyone?
cheers Peter
hey all... well I've finally been able to play around a bit with the bike and found that whoever worked on the bike last time put the intake manifolds (boot between carbs and engine) upside down. So instead of having a "perfect" circle passage into the engine, it was blocked by about a quater inch.
Once I put them on correctly and some minor adjustments runs much better. Although now I replaced the stock mufflers with some 15" emgo universal slash-cut mufflers (still 2 into 2 system) and am back to running lean with backfiring.
Another thing I noticed is that the bike is very difficult to start with the electric starter but if I pop start it starts up fine... Why?
i've had similar issues with my 81 cm 400t. you can check the valve clearances in about half an hour if it's your first time. download a pdf of the service manual. i think i needed an 8mm, 12, and 14 socket and some feeler gauges. That's all it takes.
when you get around to syncing the carbs remember that on some of these cm400's you can only adjust one side, so just match it to the other
