Because one can never have to many RC units
going to try and trade it for an ARD set up and some other bits for a bike I am building
My daughter-in-law would love something like that. If you don't mind my aasking, what can something like that set you back?
3/8 fuel impact, and a drill and hackzawl. This was a much needed upgrade.
I really love the 3/8 impact, it has 1400 in pounds of torque and its very easy and lightweight. I will hardly use a regular ratchet if possible now!
All 3 of these cost me about $250
Brand new or used? He got that for $300. I've got two- one for $150 and the other for free. Brand new, they range from $1500 to $3500. I can help you search if you want.
Tim said:
Would need some serious amperage to run that - 30? 40A 220 circuit needed?
Typically, 50 amp circuits are required. Some are as much as 60 amps. Industrial power is 208v on these, or home voltage is 240v. You can also get them in 3 phase.
The unit states 45amps. I've contacted an electrician to run two 240 circuits into the garage on a 50amp breaker. It will heat to cone 6 which is 2250 degrees Fahrenheit.
Charlie, Deviant was a big help in my search and like he said, I was able to pick this up for 300$. It's a bit older but it's in pretty nice shape. This is big and will hold alot. I'm still working on where the hell to put it where I can build a venting system to the outdoors.
1999 Triumph Tiger 885i (fuel injected)
She sure isn't pretty, but after a new ECU from ebay I have SPARK!! Not sure what to do with it yet. Was thinking of an Ice bike for the lakes up here in MN. Might not get her done this year, but ready for next winter for sure! 8) ;)
Picked up another 2000 ZRX1100 with title today. Sweet deal. Same year and color as mine. It was registered and running up until about July 2012. I was then abandoned until a salvage place picked it up and the PO ended up with it. A bit beat and I'm expecting bad things from the bottom end of the engine. Other than that it's all there and in good shape. An un-molested wiring harness, nice plastics, tank is perfect inside but kinda beat outside. I'm going to get it running and see what the "knock" sound really was and go from there. I got it as a parts bike for my other ZRX. 2 must be better than one.
Ichiban Moto said:
bad ass disk lock kit ;D
here is a video:
http://youtu.be/2IbcvUVp7Ik
I cant tell if you took out an actual adapter and replaced it with that bit, created a 'disk lock' page for the front of a normal padlock package, or if that's real.. I really hope that's real
