Tune-A-Fish said:Okay. Those are cathode anode type no neon, or any neon I'm familiar with.
Just checked wikipedia. They're "cold cathode displays". So yeah... I think you're right.
Sonreir said:Just checked wikipedia. They're "cold cathode displays". So yeah... I think you're right.
surffly said:Bought some Withworth wrenches (snap-on because I am a tool snob) to start working on my Featherbed.
canyoncarver said:Man, I need to get mine going too.
DohcBikes said:Yep bolt on big bore top end
DohcBikes said:I'll wire and fire it this week then get back to ya. Assuming all is well i'd let the entire top end go complete for $100 plus shipping that'll be about ten bucks.
Jug
Piston, clips, pin
Head complete and assembled
Camshaft
Advancer unit, CDI if you need it.
Again recommending the 200x piston (the atc200 pistons are only 8.2:1 dished) but there's a wiseco 12:1 dome that'll drop right inrace gas only
Still though 200x flattops are my favorite!! Great power and run on 91.
Go with a+1- 66mm bore for even more fun, still leaves room for one more bore because they readily offer 5th oversize for the 200x. Obviously the 1mm larger bore with a flattop that runs 9.6:1 in a std bore would put you even closer to that very sweet 10:1 range.
Either way the xl185 will scoot.
I am certainly intrigued. I've read about guys using XL175 top ends with CB350 twin pistons to convert ATC90s up to 300cc. But I haven't seen this possibility. It would be nice to find some form with that 175 motor.DohcBikes said:Yep bolt on big bore top end for dozens of old Hondas. Snatch up a cheap 200x piston and you have 9.6:1 compression as well. Will fit on to so many honda singles I can't even remember them all.
