powdercoat versus brake fluid
Mr.E
Got to keep the loonies on the path...
so I noticed some brake fluid leakage last night on my front wheel. My dad had been messing with the master cylinder last week, so I'm guessing thats when this happened. A little has dripped onto the wheel right in the bead area, and ran downhill for a few inches. It took the powdercoat with it. Bubbled right off the rim. Is this normal? Did I waste 100 bucks on a crappy job? I had no idea this would happen to a powdercoated surface. Any ideas where to go from here? it's not THAT noticeable, but still I know its there, and that is not ok.
Brake Fluid is naturally a good enemy of ruining a paint job. Never seen it against powder coat but I would imagine it would do the same thing with enough time.
Always remove brake fluid drips asap. If you can't, wrap it in a towel or plastic until u can fix the leak...or isolate the leak.
yes. its normal. brake fluid is a mofo at getting paint and powder off.
