Powdercoater issues/questions
timdhawk
Powdercoater A:
Dan says no problem to pre blasted parts. Also uses phosphate bath to clean parts before coating. Price quote:$500 for large portion of bike.
Powdercoater B:
Pierre says big problem with pre blasted parts, no phoshate bath cleaning, 1-2 coats needed, and spent 15 of 20 minutes extoling his own knowledge and virtures and why he's the best and the last 5 giving me the quote of about $600.
So ... Who would you choose? (that's kind of a retoricle question)
from what i understand about power coating you will not get a lasting finish unless you strip it down to bare metal and then bake the bare metal for 20 minutes at 400* to heat the metal and remove any impurities from the surface before putting on the powder then the part has to bake for another 10 minutes i believe at 390* and the 10 minutes does not start until the temperature of the metal which you are coating is up to 390* so i wouldnt trust the guy that's telling you he doesn't clean the parts before coating. just my $.02
i know very little about powdercoating so bear with me. I do however have a cheap gun and do all my small bits with a toaster oven. from what I read the pre-baking is only required on CAST parts. a frame is not cast.
also I got my frame, swinger arm, fork tubes, and both triple trees done in wet black. this was blasted, primered and coated.. all for 250$$ id shop around.
Those prices are high, unless they include the wheels. I established a relationship with my PC guys, and I pretty much spec out what I want. They guide when needed.
For thin aluminum, I'd just have it dipped.
For steel bike parts, I'd have it blasted for sure. They typically dip afterwards.
On porous metal like cast aluminum, it does need to be blasted, then baked, then dipped.
The best PC jobs will include a hot coat, though I typically never spec that. They did hot coat the wheels on my RD400 for free because they thought that it was required.
For reference, I paid $80/wheel and $350 to get the entire RD400 powdercoated. I think the CB360 cost me something like $300 for everything, not including wheels.
--Chris
i should say this is a CB750 frame, swing arm, both hoops and hubs, triple tree, fork lowers, and some misc smaller stuff. All parts have been either bead or sand blasted by me prior to going in.
In Toronto I paid $250 or so for a frame, two swingarms and a bunch of smaller brackets etc. done in gloss black.
That included all prep work. I showed up with dirty greasy parts. They blasted, plugged holes, coated and then wrapped the parts in paper to protect them.
F**K ME!!!!!!
I almost feel like an ass-raped inmate! Upwards of $700 for 2 colors (maybe 3 if you count clear coat). parts coated:
frame, swingarm, fork lowers, hoops, hubs, kickstand, 2 motor mount brackets, front caliper assembly, and an electronics pan.
Even with everything blasted, they said it was still a lot of man hours to mask and plug everything.
I need a beer!
Did you pay that much? If you got three colors done, that might not be such a bad price--maybe a little high. More importantly, let's see some pics! I bet it looks really good.
--Chris
i do powder for a living, i would NEVER let anyone prep somethign i was putting my name on... ever! prices all depend on what you are having done, condition of the object, and colors selected (solids, dorments, duel layers, etc)
--Chris
Haven't paid that much yet. he said he would try to help me where he could, but that a lot of the cost was in the masking and plugging of everything. It will be 3 colors worth when done, one of which is a clear coat. However he said he wasn't gonna charge me for the clear since i did all the balsting myself.... so still a big $$ pill to swallow.
I can see that line of rationale. In the end, im not sure i would do it again... the pre-blasting. I only did it because i thought it would save me some money overall. Granted, i prepped really well, but still...I'de hate to see what the bill would have been if i hadn't prepped!
The cost qoutes i recieved were all in the same ballpark from all 3 places in my area so i think i just underestimated my job.
masking and plugging does not cost JACK for supplies, once we own then we own them. i know we order tape in bulk and all our plugs a sylicone, that are used over and over, in 1000000 of sizes. the issue is IT TAKES TIME! LOTS of time... and on some HUGE items that need alot of masking, if he does not have the right supplies the costs can get up there using what you have and trying to make it work. we learned that a long time ago and now ensure we haev the right supplies for the job... My main issue is what media are you useing? the profile really makes a HUGE DIF! exp if you are laying powders... if you do not prep the surface right you will get fish eyes and orange peel like NO TOMORROW!
