firebane said:So I want to get my bike running but the electrical is in shambles. So what I want to do is hook the battery directly to the coil with a inline fuse and kill switch.
Question is will this work and will this drain the battery?
regal7point5 said:Make sure the kill switch is properly rated for the load it will see. Even though it is temporary, is the starter wiring going to run through the switch? If so, most switches wont handle the load, or won't handle it for long. A relay would be better/safer.
regal7point5 said:Correct...if kick only and you are not wiring up a headlight, any switch will work.
