So I know a few people are using the powersonic battery in their bikes but I am wondering how do securely connect my battery cables to that.? do they make a 6 or 8 gauge quick connector end that whould just crimp on? what are you guys doing?
For those you would use female spade connectors. Depending on you plus and minus wires you would probably use the yellow or red crimp on type spades. You can cut the plastic sleeve off of the spades and solder them on to your wires and use shrink tube over the solder connections. Soldering is always better than crimps, but I do use them a lot.
It's important to note, however, that neither of those spades is actually designed for 6 or 8 gage wire (in a sense). Yellow crimps are designed for the largest wire while still being a 1/4" spade, and those are made to take 10 to 12 gage wire (stranded). 6 or 8 isn't going to fit nice... but you might be able to make it work. I wouldn't want to crank that starter for too long if I were you! Things will get toasty. If you have a kick of course, no worries there .
awesome, yea the 5 amp might be a bit weak for the starter. i was planning on just a kick only. i am thinking 8 gauge is the thickest i will want to go cable wise.. is that going to cause any problems with the rest of the electrial system if i am running 8 gauge wire where 6 gauge used to be? i am hoping the 8 gauge will cause there to be a little less heat at the terminals
The whole electrical system is usually a pretty light load. Take your lights wattage and convert it to amps and total it up. If you have a CDI, then your lights are the whole load on your electrical system. If you have an electronic ignition, those are usually about 200 watts or less. Given that your bike has a kick start, it's probably CDI?
In any case, come up with the total worst case amperage load (remember Watts= Amps times Volts) for your bike and compare to the chart found here. Basically, if it's higher than 40amps, you probably need 6 gage, but I highly doubt you are. The starter is what makes most vehicles have such beefy wiring.
