preparing flat surfaces for gaskets?
overdraft
Coast to Coast
hi all! i was scraping off old gasket material with my 'factory approved' old wood chisel and even though i had just sharpened it it seemed like i was doing more harm than good to the mating surfaces...
so then i got the idea that, since i have an unobstructed flat surface, why not 'lap' them by putting some wet/dry sandpaper on a flat surface... it worked like a hot damn for getting rid of the old bits of cooked on gasket as you can see by the before and afters...
BUT!!! there is tiny scoring on the surfaces from the sandpaper (i used 180)... does anyone know if the gasket material will make that up ok? or do i have to now use ever finer grades of sandpaper, and if so, how fine do i have to go? OR have i just effed up my parts and need to buy new ones...
thanks for the help!
Really you should have them faced but that looks like the alternator cover...? You should be ok. The problem that I see it that it would be an uneven surface, even if its by a fraction of an inch. In your cylinder of valve surfaces that would probably cause leaking but for the others it may not be as big of a deal.
Just flat sand it again with finer paper, 400-600 wet paper should smooth it out. Yes, the gasket will seal minor surface imperfections.
ya alternator cover and i did this with the case covers as well... so only has to be oil-tight, no pressure or alignment issues... thanks for the input! i'll do another pass with 400 (because i have lots for some reason)
DrJ is right as usual. You can also use a VERY small amount of HondaBond or similar substance to mate the gaskets to the surface as well. Will help seal it all up. LESS IS MORE though... Dont over-do it.
Indian head gasket shellac. Paint both sides of gasket (paper?) and let it get tacky before assembly.
tape a piece of 400 grit to a piece of glass and rub it down on that. it ensures you get an even finish.... otherwise you may have a wavy surface. get me?
a very thin coating of Permatex #2 Aviation cement or 3 bond. No need to sand again. With the Permatex you want a nice thin even coat on one of the surfaces. The permatex never really dries, it always stays a little pliable.
The trick is to use as big, solid, and flat sanding block as you can find. Sand across the piece, keeping both edges always under the block. As soon as you sand 'around' the outline, you increase your chances of 'rounding' the face. Keeping the block square will give you your best sealing-surface.
The glass-thing works too, like rocan says. In this case, you put your glass (the thicker the better) on your bench and rub your piece on that. If you know what I mean ;D
I finish them with 400 wet & dry.
cheers
ian
We use the technique that Rocan was talking about at work, except with an actual "lapping block" made of heat treated steel that's cross cut about 1/4" deep and 1/16" grooves. We use some 280 grit (Clover) lapping grease and then go to town with whatever we are lapping in a "figure 8" pattern. We finish it off with 4000 grit diamond dust polish. You could probably shave in the reflection of some of the stuff we do... But in your case, a thick piece of glass and some fine sandpaper (400-600) should be plenty smooth enough.
It's close enough as it is as long as you used a flat surface - sheet of glass is good.
No need for any of those gasket goops. the gasket should seal fine at 180 grit.
Clean out all the threads and lightly countersink the holes on both mating surfaces and you should be fine.
If you want a really fine seal - this was how we made Brit bikes oiltight in the day...................... 8)
A piece of thick glass [ 1/4" + ] on a flat bench surface / whatever - my coffee table in the lounge used to work well !
Then use valve lapping / grinding paste. Put the paste on the glass and then press down the surface to be lapped and use a circular motion. Usually there's two grades of paste in the can - finish off with the smoother of the two.
Not only will you get a super smooth finish, it will also be perfectly flat.
Reinforce the quote about cleaning up afterwards - the paste is carburundum based - don't want that in your oilways !! :-[
IF the surfaces are obviously badly bowed [ eg. alloy cylinder head] - then a large flat file run across the surfaces at 45 degree angles is the first step - followed by any of the above.
To add to that last post: The file should be placed on the surface and drawn across the surface not filed in the usual way. That's why it's called draw filing. It's a different process and I still use that regularly on old motors.
for low pressure things like case covers, that's fine, the paper gaskets expand when oil seeps into them, so they're more or less self sealing. for things like a head gasket, I only use copper gaskets now and spray a copper gasket material on both sides, works like a charm and prevents the gasket from baking on to the head too, from what I hear, you can also use the copper gasket spray on the regular composite head gaskets
you can, I used permatex's copper spray gasket on my 455 olds heads, this is actually highly recomended by Mondello (huge Olds hotrod shop). But you do NOT want to use the spray copper stuff on Fel-Pro's Print-O-Seal head gaskets.
A 12" square marble tile with a sheet of wet-or-dry sandpaper of the appropriate grit cemented to it works well.
CC
from the pic it doen't look like you removed much, but if you put the cover back on -no screws no gasket just hold it - you will get a better idea, it should feel solid and give a nice clear snappy sound when you put them together. the line between the two should also look tite and even.
