problem with reinstalling control swiches on cb350
cabrito
i'm just installing new bars on my 71 cb350, took them off and i thought everything was fine and i THOUGHT i was paying attention when i took them apart but apparently not..!
basically, the horn and the start buttons don't work. and the highbeam won't come on now. the ignition works, i turned it on, set to run, and it fired up with the kickstart, so, i'm pretty sure it's not from rehooking up the wires the wrong way. the little "switch" that makes up the start button kinda came apart when taking apart and i guess it could be that i'm not putting it together wrong but i didn't take apart the horn one and it doesn't work either.
i tried a volt meter, at the connection in the headlight, and it seems that there might be a short in the switch/button area but i'm not totally sure.
i did also just noticed that i needed to put a second little hole in the bars to line up the controls.
i'm pretty sure i'm either somehow putting the controls back together wrong on the bars, or (more likely) i've put the internal parts back together.
has someone ever run into this before or does someone have a suggestion or a close up of the inside of the switches..?
thanks
flynn
woody1981 said:
Make sure to check all your ground wires.
- Woody
i had a feeling this is probably where the problem is. since i don't have a wireing diagram and i'm kinda stoopid when it comes to this whole electricity thing...can you give me a headsup on which ones i need to check....if you know.
I'd run an external ground from one of the bolts to the frame. Woody is right: it's likely a ground.
--Chris
