mannydantyla
Introduction:
I bought a used vacuum gauge for diagnosing a chevy 350, and it came with a used compression gauge and says Milton on it. Both for $15. Score! Now I can finally check the accuracy against my roommate's compression gauge he bought a Oreilly's. The package says "Ennova Equus Hi Tech Tools." Both have the exact same hose length and ball valves at the end of the hose the goes to the spark plug hole.
The specimen:
My '74 CL200. About this time last year, I rebuilt the engine, including new pistons and rings, and had the cylinders bored and honed. I went through the "break it in fast" break in procedure for seating the piston rings as many others around the forum have recommended. I checked compression with the Ennova Equus gauge every few hundred miles and in never read over 120psi, a disappointing figure. None the less, the engine has plenty of power, enough to get my girlfriend and I up hills and at highway cruising speed (well, 55-60mph) without too much worry. So now, I finally have a chance to verify if compression is good or not.
The test:
I warmed up the engine and began checking compression. First was my roommate's Ennova Equus guage. Choke not engaged, wide open throttle, kicked the kickstarter until the gauge stopped moving.
500 miles after I last checked it. It showed the same 120 psi it always had.
Now to test the new Milton gauge. It feels like much higher quality and says it was made in USA. I tested it the same method as before, same cylinder.
20 psi higher! Also, unlike the other gauge, this one didn't slowly leak. I could just leave it there and the needle wouldn't change. The other gauge would slowly drop.
The results:
So the new gauge says each cylinder is 20 psi higher than with my old gauge. 140 psi.... not excellent but I'm happy with it. I also have a can of "Engine Restore" that increases compression by adding zinc to the oil or something, I've read a lot of great reviews, but I think I might hold off on using it with a motorcycle, especially one with a wet clutch. Your thoughts?
Hope this helps someone!
The specimen:
The test:
The results:
