Project 500
peke
see if this works...
So, at last... a few moments to try and show what I'm up to.
As I said in the introduction section I'm turning a 2001 CB 500 twin into a cafeproject. The base is a perfectly good bike so I won't have any serious technical problems.
This is what she looked like before I started molesting her.
Hm.... took a look at the preview.... Why doesn't it show the whole picture? affraid
A little later I had taken off all of her clothes and I thought...... "She looks mean"!
I'm planning on keeping the tank as it is and I don't want to spend too much money, so I will be using bits and pieces I have around here and make as much as possible myself.
Now, time for a bit of updating:
When I had taken off her clothes I sat there and looked at the metal mass on her backside. No way a slick seat would fit upthere...
After some thinking help came from an unexpected side..... A little frozen devil started whispering wicked things in my ears..... "Cut it off, cut it off" it kept saying
And so I did... After a painless but noisy amputation she now looks like this.
We're past the point of no return now!
So kind of you to relpy... keeps me going! (the devil is called Raki)
After I had cut off her butt I started to think about something to sit on. I looked around the house and found a shelf that nearly had the right proportions in the basement . So after some sawing and grinding it looked like this:
A fine start I thought and I started chasing one of my little frozen devils to celebrate the occasion. The little raskall dove away behind something very usefull. A few minutes later the back of the shelf was loaded with some pieces of isolationboard.
It then was time for some serious cutting and slowely a shape came to be...
and more cutting
Now I had to apply some protection to prevent the resin to cover the seat to destroy the foam. So here you have a sneak preview of what her new butt could be.
That's looking pretty nice! You should expand the front of your seat to completely cover the detent in the back of the tank and the 'gap at the bottom/rear of the tank. If it's upholstered it's going to really tie the bike together.
Regardless....props for taking the less traveled road!
Welcome guys for a new session.
After cutting and sanding the white boards into a nice form it was time to aply the glasfibre. A smelly job even if done outside. On this picture you can see the hardened glass shell. One starts to wonder if it's ever going to be a smooth surface.
After a first attack with the sanding machine things look even worse. Awefull!
The icing on the cake.... filler all over!
After removing the exess filler this is what's left:
Much more filling and sanding to come!
To break the silence here: Time for an update on the project.
between the episodes of filling and sanding the seat there is time to do some other jobs, as there is removing the exhaust followed by cleaning and painting the headers.
I wonder how long the "heat resistant" paint will hold.
Since she will never again carry a passenger I decided to do something nasty to the enormous footrests:
Oops
painting
and now before and after in one picture
Footrests re-installed
that's all for now! Feel free to post coments.
Time to talk some more about the seat: After numerous times of filling and sanding it looked like this:
Looks like it's going the right way, but I still have a long way to go. After grounding and wet sanding it got even better. Light at the end of the tunnel?
Then the moment came I dared to apply the first coat of color
Not bad uh? So on with the second color.......
But then disaster showed it's ugly face in the form of the clear coat.... I applied a coat that was too thick and it reacted with the paint affraid I did not take a pic of that, sorry but I only want to forget that phase as soon as possible. I had to sand it all the way down and repaint it. Now it's back ok, but I still have to clearcoat. whish me luck please!
While you're at it, you should think about shortening up hte seating section a bit as you've cut off the passenger pegs. Leave yourself enough room to move about a bit but you don't need that much acreage unless your posterior is....errr....sizable.....
;D
I see your point there. I could cut it a bit, but that means I will have to relocate the licenceplate to the side... Don't know if I like that. I'll give it a thought!
My last paint job I had problems with the clear coat...seems like certain paints do not work well with clear coats. Really like that color scheme.
peke said:
;D
Naw, just hang it off the back with a small tail light and you'll be in proportion and the girls will all want to get with you.....no.........really.........
seriously.....
I wouldn't joke about that.
I hope my wife won't read this "girls" part or project 500 will come to a sudden stop... ::)
No serious if I make it shorter I will have to relocate the licenceplate for lack of space between the seat and the tire >:(
