ldordai said:Just a thought on those ears...
How are they made? If they're fiberglass, you could sand the top and bottom of them down until you have enough space for the clipons. Just put painters tape around where the ears wrap around the fork legs, and when you sand the painters tape will prevent the fiberglass from splintering. That would give you a win/win, because you would get the headlight down a little lower and you would lose the handlebar clamps, giving the whole bike a more aggressive stance. If you wanted, you could probably get a second set of ears from benji (seems like they wouldnt be more than 20 dollars) and file em down before you paint them.
johnny gaijin said:have you seen what mysta2 did with his clubmans? i don't know if it's the safest solution but as far as i know he hasn't had any problems...
JRK5892 said:well then... if you are going to coat them any way... personally... i would take the clubmans. remove your risers. cut off the clamp part of the riser, notch the riser pegs that are left, and weld the clubmans right to that, would be smooth all the way across and a very unique look, and once coated they will be perfect, that will allow you to get the bars tight to the trees, have a uniqe look... but you would not be able to adjust them so be sure you mark out just where you want them first... that is what i would do on them... hell may do that on my CB500 now that i think about it!
JRK5892 said:i use a pipe notcher that i got from harbor freight... works great man, we build bars with it all the time!
wold be easy to cut and notch the risers... then have him weld them up!
http://www.harborfreight.com/pipe-tubing-notcher-42324.html
JRK5892 said:i am gone the rest of the week up north with the wife... she got a new snowmobile last year and has been all over me to go out on the trails... got the trailer hooked up and packed just waiting on her to get home from work... be back on wed
xulf13 said:So I take it you're a HALO Fan?
66replica said:In other news, the battery I've been waiting for since NOVEMBER 30TH has arrived. USPS sucks. They lost the first one but the seller is a good guy and sent me another one. Taking bets to see if it'll run the 360 without the electric start.
