project: Spitfire
oh yeah.. full strokes for sure! I also used some body working tools to help smooth them at the end. I didn't want to remove material by sanding so I just got a big steel block and used it to help remove tool marks. worked well.
It's been a while but if I think of more tips I'll shout em out!
yeah, we're going to try again this weekend, I did another bucket in fiberglass and made a mold too, because I wanted to not have spinning the headlight hanging over my head, and just do it with no pressure. I am putting together the 750 and the idea of spinning the stacks the same shape as the stock stacks had definitely crossed my mind
The cool thing about spinning your own stacks is that you can try different sizes to see exactly what's going to work the best for your bike.
Saw you bucket and it looks really good
had some time to put this build in the schedule this weekend... the owner is also getting antsy as the weather warms up! ;D
cleaned up the engine, painted it and will be polishing the cases, I saw this color theme somewhere on here and loved it
fabricated the rear brace replacement
will be running a ups battery, so I fabbed up a stainless battery/electrical tray
I like that a lot, the tail in particular.
If I didn't just pick up a headlight, I would hit you up for one of your "defective" buckets.
Wow, missed this thread somehow. I'm really impressed by your seat and exhaust!! Wow! :o
got the motor all polished up and refitted in the frame for final fitting of the exhaust so we can get it powdercoated next
is the full travel of the front end going to clear the exhaust? Maybe its just the angle of the pic, but it looks like it sticks out pretty far.
yep, compressed the front end when building it
BCBarker said:
I never re-tempered the bowls after tempering. I spun a lot of copper and as long as I annealed it well before and didn't spin it too thin, I never had a problem with it. The initial annealing seamed to be enough to "loosen" the molecules and no further tempering was needed.
It may help, But I never did it.
FYI - when annealing copper you stop when it's glowing red with the lights off. If it's glowing red with the lights on, you have heated it too much. Not sure about aluminum.
I use a heat marker on aluminum. I find it near impossible to get the planishing marks out of aluminum some times.
rockcitycafe said:
Simply STUNNING work! Gotta ask tho:
1. Where or how did you come across those Girling style fork springs? :o
and
2. What might that pink-attired beastie behind the Spitfire be?
remove the cow bells and you can see the springs on CB 350s
man i love everything about this build, has such a smoooooth flow to it, that front fender is by far my fav part man, just awesome! wish you where closer so i could toss one of my LED kits in it and just make it really glow with all that metal work! just awesome stuff bud
