Pulling a SOHC CB750 motor?
I've never had any success laying motor on it's side and draping bike over it.
It may work with a bare frame but isn't practical with a complete rolling chassis
Redbird said:
Aw man, that was painful.
Cuts the intake manifolds because the clamps are rusty/stripped?! I kept expecting him to hack the frame to get the motor out :o
I had to post up the following pic, simply because I was laughing at myself for doing exactly what I was bagging on him for. Of course, the major difference is, this frame was/is junk (rusted through in places and untitled) and I have no expectation of using it again.
I was trying to get down to the cylinders to get a pic for mysta2, and forgot that the engine has to come out just to get the valve cover off. So I made clearance...
The good news is, it worked :D :P
What did you cut that with?
An axe? ;D
You can get weld in repair pieces to bolt it together, someone on SOHC4 makes them
it's actually not all that hard, you need to rotate it ccw a little bit (looking from points cover), then remove through the right side of the frame, one person can do it as long as there's something to hold the engine close to the height of the frame... you'll be bleeding just a bit afterwards, but not much...
