Pulse Generator Timing
Red Fthr
"Man is born free, and he is everywhere in chains"
I'm trying to help my buddy set his ignition timing on his CB750 DOHC. I've done points before and can work my way through Dyna ignition plates, but I've never seen or done anything with magnetic pulse generators. There's no red or blue cables. Nothing I could even get a test light on. Does anyone know who makes this or know how to time it? Is timing it even possible or is it a set-it-and-forget-it kind of thing?
Finding the manufacture would be helpful enough, as I could probably find instructions online somewhere. Thanks guys.
Somebody correct me if I'm wrong, but I think that is the stock timing mechanism on a DOHC. I have a 79 and while I haven't taken the timing cover off, I am pretty sure that is exactly what it looks like in the service manual. I also remember reading somewhere that one of the biggest upgrades to the DOHC vs the SOHC was electronic ignition over points.
Is the timing off? If not it should just be set it and forget it.
I was wondering if that was stock or not (I've never worked on anything older than 75). I need to grab a service manual if it is. He's having performance issues that seem to be more electrical than mechanical (if that makes sense). Was hoping the timing was just a lil off but maybe not.
Just pulled a manual aaaaaaaaaannnnnnnndddddd I'm an idiot (well ignorant). It's stock and there's a whole how-to in the manual. Thanks
No problem, If it is like when I did the Dyna on my CB500 it looks like it's probably spot on (eyeballed horizontal my 500 and it wound up being dead nuts on). But I haven't had to bother with timing on this one.
If I'm correctly picking up what you're putting down, could it be coils, or as simple as plugs?
Plugs have spark, so I don't think it's that. It started sputtering on him and loosing juice the other day as if the battery was dying or as if it were running out of gas, but the battery wasn't dead and there was gas in it. Leads were tight, gas was on, and choke was off.
Kind of stumped now. Maybe one of his carbs is getting gunky or something? Shouldn't be though. They haven't been touched. With that said, maybe it's been too long since they've been touched.
also, even though the battery wasn't dead, it still had a hard time starting on its own. We had to push him once. I've seen things like that happen (weird start, bad performance, troubles idling) due to off ignition timing. Maybe there was enough of a draw on the battery while he was riding or maybe there is something carb related going on.
I don't usually throw parts at the problem... except for plugs, if an issue started that wasn't there before I'll throw some plugs at it. That said I had some similar issues with mine when I bought it last fall.
how is the tank? clean or rusty inside? Mine would barely run even though there was gas in the tank, when I flipped it to reserve it died entirely. The petcock was clogged with rust. Fortunately mine came with a clean (all be it ugly) tank that made things better.
I also think I have a vacuum leak that I am chasing down. My carb holders on the engine side are rock hard, which will often lead to a leak situation. I have new ones in the mail right now which I'm hoping will alleviate the issue.
Did you check compression?
It might be DOHC, but it's still a simple air cooled motor so it can only really be a handful of things.
That's what I'm thinking. As I dig deeper, I'm finding out this is a really dirty bike. I'm going to check all of the above, starting with the petcock.
