At the risk of sounding like a smart arse, it should come with instructions.. They use a magnet which is glued or bolted to teh front hub and a sensor and wire. The sensor is bolted to the forks or disk caliper mount and that usually has a plug on the end that matches the Speedo wiring.
It's not as stupid as you might be thinking. If you haven't fitted an electronic speedo before, there's no reason you should know how they work. I didn't know until I bought and then it was obvious . OEM electronic speedos like a GSXR use a sprocket tooth counter and feed that to the ECU and it send that data along to the instrument panel.
