q? what goes between your custom fiberglass tail and the frame?
termigni
Hi, i am a newb but I would like to make my own fiberglass tail for my CB360T. I've read tons of posts here about making fiberglass tail but almost none of them go over how to treat the bottom of the fiberglass to support your butt.
so anyone have pictures of the bottom of the fiberglass which will actually touch the frame?? what do you put under there? ??? ???
I just cut up an old tire tube and glued it to the fibreglass where it would touch the frame. So far it's worked fine.
thank you for quick reply HerrDeacon.
I made a quick illustration of what you said:
So how many layers of old tire tube have you put?
also another question that comes next is how do you attach the new fiberglass seat on the frame so that it doesn't slide off the bike while you are riding?
Nice pic. That's exactly what I did. My frame is not flat and so my seat only touches the frame and a few points so my patches of rubber were pretty small.
There are different ways to attach them but I used the existing bolt holes for the battery box. Just picked up slightly longer bolts and drilled four holes in the seat pan.
