question about gel batteries
XsjadoTwin
Quick background 1975 cl360, I do not use the electrical start and have a 12v 9amp acid battery. I'm needing to go smaller in actual dimensions of the batery and found a 12v8amp gel battery that would fit like a charm. but will this lack of 1 amp kill me?
what type of signal and head light(s) are you running?
Any other modification to your electric/wirring?
a 35W halogen headlight, LEDs in the pilot box, except the blinker one, an LED taillight, but a regular worked fine too. Also I did the upgraded charging mod where you connect the two wires coming out of the stator together which tricks it into thinking the high beams are on when they arent, which makes all 3 pairs of coils in the stator charge instead of just the two, giving you batter charging rate. Look on hondatwins they go over the mod, pretty easy to do.
The battery serves as a reference points for voltage for the regulator, and storage for electric start and when the engine isn't running. it also serves as a reserve if the alternator output gets low (below 3000 or so RPM).
So if you are not idling a lot, and keep the revs above 3000 RPM most of the time, as well as not using electric start, then a small battery is fine. Above 3000 RPM the battery is not contributing anything to the system, other than providing a reference for the regulator.
Cars are the same way. they run on the alternator....The battery is for starting, and letting you have lights when the engine is off.
I recommend Sonreir's regulator. It will keep the charging system from overcharging the battery. Small batteries can take a beating with the relatively crude charging system on our bikes.
Sonreir said:
Are you running with the electric start or just the kicker?
The OP mentioned that he doesn't use the electric start :)
To the OP - you shouldn't notice the loss of that single amp. In my professional opinion, gel batteries are always the way to go. More cold-cranking amps and, honestly, a much safer battery in general. Go for it mate :) Cheers!
