Question from a newb
carni123
Hi all,
I've been working on a 1981 xs400 that had sat for a few years, and I'm making progress. I've got it running, and it "seems" to be running pretty good. One thing I've noticed though is that one side of the engine takes much longer to get warm, or it could be one side is getting warm much faster than the other. Either way, it's puzzling me and I'm not sure what I should be looking at for a problem, or if there is one at all. ???
Just fyi. Within the last couple of months I've rebuilt the carbs, replaced the spark plugs, cables, caps, and one of the coils, changed the oil twice, oil filter once.
Any suggestions would be very much appreciated.
Ryan
Sounds like one side could be firing intermittently, or maybe your valves need adjusted. My 77 XS400 did the same thing. Have you done a compression test? If you haven't you should, and then adjust the valves. Adjusting the valves brought one cylinder up 65lbs. Its still weak compared to the other side, but I was surprised at the increase nonetheless. Bottom line, is it isn't firing, it won't get hot.
Also, what do your plugs look like now? can you get a read on them yet? I think if you are running rich on that side, it may exhibit similar symptoms. Someone correct me if I am wrong. Conversely, if you are running lean, I believe the cylinder should be excessively hot. If you aren't sure what your plugs should look like, they should be a tan, to chocolate milk color, and free of carbon build up. Run the bike for a while and pull the plugs, check to see if they are wet, and smell like gas, or are very dark with carbon. If so, you are running rich. If they are very light in color, or white, you are lean.
Good luck, and ask questions.
Later,
Ryan
