Steaksauce
So I'm redoing a 72 SL125 for a bike to cruise around town on. My question is will the forks be ok for the street or should I look In to CB forks or even the whole front end?
a bandsaw ? no, you will ruin every blade :nrcb125 said:They'll probably be fine on the road. Ride the bike as is for a bit and then make adjustments. If you want to replace the wheel to get a disc brake up front that's another story...
Rather than replacing the front end you could try stiffening the springs a little and changing to a slightly thicker fork oil.
To stiffen the springs cut a little bit off using a band saw for a clean cut and add in a spacer to make up for the length removed. There's a bunch of calculators on the internet to help you figure out the new rate. This will make the front end stiffer.
Here's a good guide to cutting the stock springs:
http://www.ex-500.com/wiki/index.php?title=Upgrading_the_Suspension#Cutting_Stock_Springs_.28_The_FOG_suspension_Mod_.29
Replacing with a heavier weight fork oil will slow the damping in the front forks. Find the recommended fork oil weight in a shop manual and go up one rating. For example if it says 10W, try 15W.
The best part is doing both of these is really inexpensive![]()
nrcb125 said:You're absolutely right xb33bsa! I derped on the name. Should have said miter box or saw. The article I linked to even says it...
yes that is true if you heat it in the middle and a large portion of the coils that is what the mexicans used to do to get a lowriderSav0r said:Heating a spring is a bad idea. It tends to crystallize the metal which leads to shrinking springs and eventual failure. Just ask anybody that's ever lowered their car this way.
