Questions for the engine guys out there.
CCRider
Coast to Coast
Though my bike (74 CB450 about 6K miles on the clock) is running really well and has proven to be pretty reliable, I felt the urge to buy a compression tester last week and try it out. I was very disappointed with the readings of about 120psi on the left side and 145psi on the right. Shop manual says 180psi is normal. The only issues I've had with the engine are hard starting sometimes and unreliable idle below about 1500rpm.
So my questions are:
Should I rebuild?
If I go to the trouble of pulling the engine, should I do anything to the bottom end or just do the top?
We've got pretty good year-round riding around here, but I figure now's the time to do it if it really needs doing.
Thanks for the help, CC
seems low... couple questions:
where did you get the compression tester? (some testers are designed for larger engine displacements, that tube is full of "dead" air and using a tester for larger engines on a small displacement bike can give lower than actual readings)
was the bike cold or warmed up? (if it's been sitting for a while, compression can be lower than actual running compression)
are your valve tappets adjusted properly? (can be a simple fix for low compression and should be checked before taking the engine apart)
did you remove all the spark plugs when checking compression?
was the throttle wide open and choke open when checking?
(make sure the plugs are all out and throttle open when doing this, compression measurements will be affected by restriction of airflow, and make sure the plugs are out because you want the engine to be turning as fast as you can get it)
Cheapo tester from Harbor Freight. I checked the guage against my air compressor guage and readings were about the same. I kicked it over until readings maxed out and stabilized, so that should eliminate any "dead air" issues.
Warmed up.
valves were adjusted about 500 miles ago, but not rechecked prior to test.
Yes and yes.
Thanks, CC
After your initial reading, you then need to put a bit of oil in the cylinder and run the tests again. If the numbers go up, this will normally indicate that the issue is with the rings. If it doesn't go up, then its usually valve related or possible a leaky head gasket.
Worth doing again as this may pinpoint the issue. No sense tearing apart the whole engine if it just needs head work.
I just have to say that I love the wealth of knowledge that is on tap here at DTT! Some times when I read through random threads I find new knowledge that has been divulged by people far superior to me in an issue, and I just think; how lucky am I to be a part of this era of information and communication! I am truely thankful to be a part of this site.
I might get some flak for this, but I am in the same boat and I went with the top end rebuild. I had issues with some difficulty in starting the bike and having to blip the throttle on idle with hot engine to keep it from stalling. Compression on a hot/warm engine with WOT read 150 left, 120 right. I spent a lot of $$ and time eliminating any other symptoms (valve adjustment, timing, ignition system overhaul, carb synch and tune, etc) and I bit the bullet this past weekend. I dropped my engine off at a forum friend's place. He told me that he will ask for $500 since I provided him with all the necessary new, NOS and/or used replacement parts. The bike still ran decently before, but this is something that I want to take care of for my peace of mind.
Well I just ran the compression test a couple more times, once dry and once with a couple tablespoons of oil in each cylinder.
Dry tests were consistent with the first try, 125psi left and 140psi right.
With the oil, I got 150psi left and 170psi right.
So I'd say I've got some ring issues on both sides and maybe more problems on the left side.
But the question remains; Is it worth a rebuild if the bike is running good?
CC
Eh from my experience with this sort of advice, the responses range from: 1. YES that is way below spec, rebuild the top end as soon as you can afford to! to 2. If it runs, leave it be till it stops running.
The downside of #2 is that evenutally it will get worse sooner :-(
I had a spare chunk of change lying around for this job, and I was getting really frustrated with the persistent idling issue so I went with the rebuild. The decision is really up to you.
Dollars to beaten dead baby seals.........it needs a valve job....your wet and dry are the same(check the numbers) percentage wise,,,,the rings aren't leaking.....the valves are ::)
I am in the middle of rebuilding mine. I had the same problems, well, it seemed to start fine. But it wouldn't keep an idle when it was hot. Checked mine and it was 130 and 135. Didn't plan on doing the rebuild right away but shortly after the test I bent a valve replacing the points housing gasket (totally bonehead move). When I took my engine apart, I found the valve seats were pretty cruddy, which is probably where most of my compression loss was coming from. However, I took the jugs off and had them honed anyway.
I say keep riding until the problems become too annoying. It isn't going to damage anything beyond what normal wear and tear would do anyway.
If you aren't going to ride it during the winter and you have the money, go ahead and do it. Honing cylinders was about $25. Will probably end up spending $40 for new rings. I got my valve seats recut and lapped for $90 but you should try to just get them lapped ($30-$40?). The torsion bars on these 450s don't like the valve seats moving when recut. Gasket kit - $40..... Be prepared to find some other problems like worn cam followers or other random crap. I had to get a new cam chain guide because one of the roller pins had broke. If you are going to do the work yourself (except for the machining) expect to spend about $300-$400.
Seems to me that if the compression increases after adding oil, then the rings are leaking - oil temporarily seals the leaking piston rings allowing the higher compression. The right side compression comes up to almost spec, indicating the valves (unaffected by the added oil) are in pretty good shape. Left side increases same percentage as the right side (due to oil sealed rings) but doesn't max out as high, indicating valves aren't sealing too good.
Right? CC
Right? CC
Either way, it's kind of a moot point.
If you're going to pull the motor and do the rings, you may as well lap the valves while you have it apart. Unless you like doing things twice.
A film of oil should raise the compression(it did!),,,if the rings are baffed (seized,stuck),, the oil does nothing :o,,,,,your compression is ,,,,,okay!..if you want it to run right,,,,,,,,spend the peso's( regrind the valves and seats...and lap them)
