Quick and easy paint stripping!
tWistedWheelz
BUILT NOT BOUGHT!
Not sure if anyone knows about this stuff, but If you are needing to remove some old paint, this is some serious Sh!t. It is called airplane remover! comes in an easy to use aerosol can and is safe to use on aluminium. It works great, and quick. You can find it at Wal-Mart, it comes in a white can with an airplane on the label. Cost about $12 per can. It also cleans dengy aluminium well, great to use prior to begining polishing on Aluminium. Hope some of you will find this helpfull!
I used it and it was horrible at stripping paint. Not really worth it to me. I used a gel type of tripper by Kleen Strip, which was about $7-$8. It's a little messier but it works a hell of a lot better than that aircraft stripper.
Kleen Strip makes a gel type stripper that is called aircraft remover that i have used with great success, makes sure to where heavy duty gloves though cause it burns the shit out of your skin.
True dat. My hands got super messed up and now they're even more sensitive after they healed. If I scratch my hands they become irritated.
I used Kal-Strip airplane paint remover it took the paint off my tank in to minutes. Then I used an air chuck to blow the paint off. Worked like a charm!
