Quick Question.......
teddpage
Over 1,000 Posts
Ok, i have a build thread, but didnt wanna start asking tech questions there.
Here it goes. Went to put on clubmans tonite (i have a '71 Honda CB450) and didnt realize the wiring ran thru the stock bars. Im assuming i have to clearance the lower part of the clamp to make the wiring work? Also, there is a small post in the underside of the controls...im assuming this has to be ground off to fit on the new bars?
Thanks in advance!!!!!
It would certainly look cleaner if you ran the wires through the bar but if you don't want to go through the hassle then notch the bottom clamp and pull out the setting pin with pliers.
Hmm...looking at the clubmans i thought it would be nearly impossible to run the wires thru them. I'd have to ballpark where to drill the holes and try to snake them thru? I have a set of carpy's bars...idk if it makes a difference? sorry for my ignorance!!!!!
First, make sure that they aren't 3 solid end bars welded together (they really shouldn't be but it would be a shame to drill holes and find out otherwise), clamp down the bars to the best riding position possible, and check to see where the levers would be related to your hands. That will decide where the wires will go into the bars. Then using the stock bars, find out how far in the hole needs to be from the ends. Here's a link to my build thread (about halfway down) where I ran wires in aluminum bars:
http://dotheton.com/index.php?topic=11770.210
The sharp turn in the clubmans is gonna be the toughest part - use some non-corrosive lubricant (I think hairspray) and maybe even some compressed air along with some fine needle nose pliers.
Good luck!
Quick tip! Take some light yet strong mason string (hardware store) and cut a lenth long enough to have a big loop at one end and the rest could snake through the bars. Tie the loop and then place the rest of the string in a loose whad in the hole in the middle of the bars goin down one side. Take a blaster end on your air hose and blast it through. You should have a loop out the middle and the other end of the string out the bars. Tie a small loop in that end, fold all your wires over it and tape elec tape around it all, as small as possible. Lube it all well and pull it through, go slow, its her first time!
It is definitely doable but it is a total pain in the ass. You want a strong string that will not snap easily. Also you can tie a small nut to the string to get it through the first time. Your gonna wanna wrap the wires as tightly as possible in electrical tape and then tie the string around the wires and wrap up the end in tape making sure it has a taper on it to help it lead the way. You will definitely need some type of lubricant. I probably put a good 4 or 5 hours into getting my wires through. Maybe you have less wires then I have but all I know is it was a total pain but in the end you will be very happy with the result. You might want to put grommets on the holes you drill in the bars to prevent fraying of the wires once they are through.
Yeah, it does suck to wire them internally but that's the cleanest way to go. I had fits of rage while pulling mine through. I eventually had to use thin braided steel cable to pull it through. That bend is a motherfucker.
