quick throttle mods
sonicwarhawk
Hey guys I did a site sesrch on ways to quicken the throttle and didn't come up with any really good ways. What tricks does everyone use? If I missed a thread post it.
"Quicken the throttle"
By that, do you mean a shorter turn of the throttle is a larger turn of the throttle plate in the carbs?
The only way I know to do that is to get a larger bell (pulley) for the throttle or a smaller bell for the carb.
-Deek
Motion Pro might have some suitable throttles for your application.
http://www.motionpro.com/motorcycle/tools/category/throttles_and_throttle_tubes/
Tomaselli/Domino/etc. throttles are also all over Ebay and some vintage sites.
Your throttle connection to the tube is essentially a cam of sorts so theoretically adding material and notching it back out for the cable to rest inside should work. However I'm doubtful because any throttle I've seen is sensitive and it's tight quarters inside of the housing-probably not enough room to do that.
Motion pro is the way to go most likely. They make some awesome products but beware of the guy that answers the phone there - he's a bit short. Knows his stuff, just not a lot of patience.
Why do you want to do this, anyhow?
My kawi requires a fair bit of rotation to go from idle to WOT. Also as a 2 stroke its ridden at higher rom than most so I find my self having to " regrip" as im riding to stay comfortable. I believe I have ample room inside my controls around the throttle tube.im going to mess with it when I get home.
