Quick tire question.
hanly2
I have a cheng shin hi max front tire on the rear of my bike. (not sure why it came like that) Anyway it is a 90/90-18 and I am going to move it to my front wheel and buy a new 110/90-18 rear tire for the rear. Do I need to buy a new tube for the rear or can I use the one that is in there? I'd rather save money buy using the same tubes if I can because I saw that tubes are like $20.
Thanks
Dave
Thanks
Dave
my 2 cents, that would be OK if it is a newer tube and there is no rust or crap in the wheel that might have started to cut into it. Be careful of pinching it while you take it off. going up in diameter a little with a newer tube should be fine. rub talcum powder lightly on the tube before puttiing it back in and make sure there is good covering of the spoke nipples etc. if not, then get a rubber rim cover or tape it carefully.
thought: remember your life rides on the tires. how old is the Cheng shin? does it look shiny and hard anywhere? I think they are fine for general riding when newer, but if it is hard, you may want to think about how much traction you would have caught in a light mist or rain. I replaced two tire$$ on my big bike: dunlop$$. the front was fine tread wise but 10 years old and hard. It actually looked fine.
It was a week after I replaced them that a left turner in a beat up unlicensed car tried to smoke us. whew. ::)when I did a panic stop with my wife on the back, I could hear the front start to whisper/squawk but its traction saved the day.
The tire looks really new it still has the nubbies on the edge of the tire, and there is no rot or cracking.
replace the tubes! Save money somewhere else, no reason to take a chance on something as important as that.
Terry
J'ville, Fl.
!/ how long have you had it
2/ how long did the previous owner have it
3/ how many miles on the bike?
4/is it worn a bit flat now like all back tires? maybe bad choice if worn to put it up front now.
is the tread pliant- soft or hard? compare it to a new one by picking at it with your nail, then try that at the bike shop or on a newer one. hard is bad, and a common mistake is to assume that no wear means it's ok. rubber "rusts" - oxidizes just like everything else, and the end result is skidding especially after light rain. Have an experienced firend look at it for you, and as for the tube thing, well, whose life is it? gonna drive fast? and make sure the rim is clean and the spoke nipples covered, even a few rounds of electrical tape will do it.
nubbies on the edge mean nothing.
I'd rather you bought a lesser NEW cheng shin thru Canadian tire ( I did) and a new tube than use the old tire with its rear wear patterns on the front of the bike. what will those wear patterns do? beats me, might be ok. might be a 60 mph tank slapper.
false economy is not a good thing when you only have two wheels. believe it or not, new cheaper rubber is actually better than old $$ tires. A person i know wanted my ten year old $200 Dunlop front tire: I refused beacuse it would skid in less perfect condtions and I would be responsible , perhaps for his demise?
I'll stop now- In short, please don't get hurt cause you skimped on the tires. I know the temptation; save money elsewhere - skip dinner at a restaurant once or twice and away you go.
brian
I'm not worried about the condition of the tire or tube, I am worried about the size. the tire on there now is a 90/90-18 and I want to get a 110/90-18 and there is only one tube on bikebandit with that size and it is $20, I don't know if there is other options for tubes as that seems like a high price?
where are you? if in Canada go to CTC and check the Kimpex parts catalog at the parts counter.
i looked at the tubes i bought at an aftermarket shop, $6.99 for a small 17" one and $14.95 for the cb450. If you go to a bike shop you won't have to pay shipping.
in Canada Kimpex has stuff like that and you could also try getting the british size that would be 4.00 x 18 I think rear and 3.25 or 3.5 x 18 front.
