hi i am doing this mod with my cj250 but i am useing the stock honda spoked wheels i have a good link that a member on her gave me ill try and fined it
so any way you have to press out your stock steering tube and press out the new forks and swop them over in my case the old stem in new forks where to small so you will have to get a spacer made up so it can be pressed back in nice and tight than you might have to put new steering stops in to and if you are useing the stock wheel you will have to get a sleeve made up to its a lot of work but i would say one of the best mods you could do and you will have to think about the rear wheel to
You might want to check out FunJimmy's CB550 Cafe Build on the SOHC/4 forum; he mated a R6 front end to a 550, and discussed some of the compatibility issues.
