RD 250 Generator Alignement
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
Hey guys!
got my engine nearly rebuilt,last thing to go is the putting back on the generator.
during the tear down i documented every step with my camera and now i wonder if my interpretation of the pics i took is right.
the manual and workshop manual says nothing about aligining the stator (plate with copper coils) and the moving/spinning magnet part (sorry im no native speaker).
so i just had to guess that the the mark on the stator must be aligned with the line with the "F" on the moving part?Is this right or am i getting something wrong?
I´m totally aware that the moving part must fit on the "bulged" part of the crank.Soo i spun the crank till the bulged part of the crank went into the "crease" of the spinning magnet part.
last pic shows my status quo.
last question:how much torque qould you guys use?
manual says around 80 NM....ideas?
thanks in advance!!
80NM works out to about 60 ft/lb. That's a 10mm bolt? Sounds about right to me.
Is there a T on the rotor? Usually the mark on the stator is mean to line up with a T when the crank is a top dead center.
hey sonreir!thanks for the answer....no there is only this mark on it.i made fotos of the other stuff thats written on the rotor...
maybe the symbol is different cuz the 250 was never made for the US?
Sonreir said:
Is there anything keyed or slotted? Does the rotor only fit in at one specific angle?
the rotor has a slotted hole in the middle.
the extiting part of the crank has a keyed end,on which this slotted "sleeve" fits.
what i did was:
i aligned the line on the rotor with the line on the ground plate with the coils.
then i spun the crank until the key fitted the slot.
then i put the nut on the end of the crank part.
didnt torque it yet.
Your set up looks like that used on liquid cooled RZ's and Banshees sold here in the US. If yours is the same, it is not possible to assemble it incorrectly. the slotted holes in the stator bracket are to adjust the ignition timing. I do not see how the marked tab come in to play. Because it moves with the stator plate, it won't enable you to set the timing with a strobe light. I also am confused with some of your pics, which seem to not match. One photo shows the end of the crankshaft with a hole for a bolt, and others show the end of the crank with external threads. I agree with Sonreir about the torque. Make sure the taper inside and outside is perfectly clean when you put them together. The taper is what really holds it together, so don't over torque. I have altered several RD's to have Banshee electrics, and I just hit it very lightly with an impact.
jpmobius said:
Your set up looks like that used on liquid cooled RZ's and Banshees sold here in the US. I do not believe it possible to assemble it incorrectly. the slotted holes in the stator bracket are to adjust the ignition timing. I do not see how the marked tab come in to play. Because it moves with the stator plate, it won't enable you to set the timing with a strobe light. I also am confused with some of your pics, which seem to not match. One photo shows the end of the crankshaft with a hole for a bolt, and others show the end of the crank with external threads.
hey mobius!i guess so too....since my RD is the last aircooled model already with electrical ignition and no points i guess the "F" mark is the alignement mark.
the rotor of the earlier RD´s look totally different.
the first images are my engine (threaded end of crank).
the last two pics i posted where just google images i found by the term "RD rotor" to illustrate how the the Rotor is fitted.You have a good eye for details :).
so my guess is:
its really hard to align the keyed and the slotted parts (rotor and end of crank) because you put the rotor over the crank end,the keyed part is set back so its hardly visible.if you align the F mark and the mark of the stator you´ll hit the "sweet spot" and the pieces fit together.
