RD 250
go!
Threat Level: giggles and sunshine
DTT SUPPORTER
i recently bought this lovely little 1973 rd 250.. it started first kick and all. it also had ape hangers on it. bobbert gave me drag bars, so i quickly swapped out the apes for those. then.. it wouldn't turn on. what'd i do?! fuse blown.. there's a short. so after 3 fuses and some fiddling, it seems the problem is fixed.. sort of.. this fuse has lasted! but now the high beam, turn signals, and tail light aren't working.. when i flip the turn signal switch to the left, i hear a funny noise, and am able to trace it.. this is what i find
ah-ha! it appears that a wire is not where it should be.. but i can't find a loose one anywhere. i really wish this wiring diagram were in color, or better detailed.. oh well. any advice is welcomed. or you can just watch me try to figure this one out :P
hello. Judging by your picture there never was a wire there, the terminal is dirty, no scratches or bends from a wire getting ripped out. Judging by the size and shape and terminals ( "B" i can see possibly an "L" hiding) thats your turn signal flasher. Easy to replace any 2 terminal flasher should work.
As for your problem with the high beam and the tail light, they shouldn't be related, best bet is to get a wiring diagram and test and check through the harness looking for problems, if there not working and not blowing a fuse you probably have a bad ground, if there instantly blowing fuses then you probably have a short to ground.
Chris
yeah, i was thinking its a short... searching.. thanks for the input chris!!!
no no, that's ok.. i'll keep it.
but, you can come get yer hands dirty and help me figure this one out! dear wiring, i hate you. really.
so putting the mulitmeter to the battery.. it only lights up when the key is turned to "off" or "park". of course, nothing when it's turned to "on". it's doing it wrong.
giving up for the evening i think. i think i'll work on gumpy.
oh yeah, headlight.. there are green, yellow, and black wires. yellow (high beam) and black (ground) aren't getting any power.
Did you disconnect any of the wiring connectors when you swapped out the bars? If so, that's the first thing to check (make sure they're all plugged back in properly).
After that, it might be a grounding issue on the bars (not sure if the RD's need to ground anything through the bars, but seeing as that's the thing you've changed, it's possible).
thanks manual, for not showing me what this is.
That's the brake switch.
You'll need a new one, they are rarely repairable
PJ
I found out on my CL350, a bad relay flasher does weird things w/ the entire electrical system. I'd start there (buy for $3 at an autoparts store) and then start deep trouble shooting.
Well, im proven terrible with electrical, but have you checked the battery yet? I know the relay in my old bike buzzes when there isnt enough current to flash the bulbs.
If flasher relay is making a high frequency buzzing it likely you have an indicator live feed shorted somewhere.
Usually wires are twisted until they short out because its easier to spin indicator mounting shaft than unscrew the nut holding it on.
PJ
