RD200 Expansion Chambers... Do they exist anymore?
VonYinzer
Over 10,000 Posts
Thats about it...
I cant find them anywhere. Apparently they pop up on EBay.UK every so often, but shipping would be nuts.
Let me know if you folks have any idea where to find them please.
-Mike
There are a couple of guys in the UK making weld together kits for them, but you'll need a tig guy to assemble them for you. The vintage ones are made by Micron from the 80s and were pretty common. I see them pop up occasionally. From what I have seen, you can get other similar cc bikes from the era that had a bigger aftermarket following like benelli and modify them. Head to chamber inlet is supposed to be 15" with a 3800cc chamber.
Those Allspeeds are really long and on long headers too. Time to roll your own. If you can accurately measure the ports and few other bits, I'll design a set for you and run simulations to see how well they work. If you want to roll your own, PM me.
You could use TA125 pipes but that would require riding between 10 and 12k all the time and that wears you out really fast.
Ta125 pipes could sap some of your power as the port opening and closing times are a fair bit different even from the rd125 motor the the ta125 motor is based on. So the positive and negative waves would be off from timing wise. There is all so the change that this would give you a much small power band to work with. Find out the port opening and closing times and any other if
Hit the wrong button. I think I have the port times for the rd200 in one of my manuals. If you need a theoretical places to start before you measure them in the real world. If you are going to go down the having them made road.
It needs port widths, angles, height, duct shape and few other things to work on the simulator software, so it takes a bit of time to measure them all. The TA125 was obviously tongue in cheek. You could port an RD to match those pipes but the volume would still be too small and it would have morphed into a race bike that's unrideable on the street.
Ok guys. Well, Ill get a 2-Stroke guy thats local to give me a hand and get some numbers. BradJ offered to help me roll/weld a set up so I may go that route.
Thanks as always!
I just emailed my mom's husband. He's been doing two-stroke performance for about 30 years now. Admittedly, he mostly works on BSAs, but I think he may know someone.
Thanks as always!
one of the guys going to bloomfield w me is into the rd's...im sure he knows of a source of chambers..
just remember to ask us..
