VonYinzer
Over 10,000 Posts
Got the bike. Ran great. Looked great.
Went over her, tightened everything up. New plugs, new fuel lines, cleaned the points, etc...
Put about 1000 miles on the bike with NO issues whatsoever.
Than one day, my buddy Greg and i were about 40 miles into a nice afternoon ride and the left cylinder crapped out. I limped the bike home and parked it.
Finally get around to figuring out the issue a little later, and find a few things.
1. There were NO air filters in the housings. I have no clue how I over-looked that, but I did and its in the past. Luckily Rich had some pod filters that fit (sort of...) for the ensuing fixing/testing.
2. The left carb is dumping gas everywhere. Rich and I pulled it apart, and realize that the emulsion tube and jet have somehow unthreaded and were lying in the bowl. Jesus... Thats a new on to me.
3. The right carb, and after some work, the left carb are spotless.
So... Carbs rebuilt and set correctly (according to the manual of course...). New coil installed (why not?). New plugs. Points cleaned again. New fuel lines installed. Exhaust cleaned (kinda/sorta... Didnt want to take them apart completely). Pod filters installed. Cylinder head pulled, piston, rings, and cylinder wall checked (casually) and pass with flying colors. Thank christ for that, after the non air filter situation... Head torqued down to spec (head gasket seemed ok). Oil tank filled with fresh Yama-lube.
Turn her on, and one kick she fires. Then she promptly blows billowing white smoke out of the left pipe, backfires, and sputters between running and dying. (Left cylinder only) The right side runs great (though a bit hot...).
Give it ANY throttle and it dies. So, everything is pointing to a really rich left (and now, somewhat lean right) cylinder, but there is no reason for it. Not that I can think of anyhow. The jetting is the same in both carbs (forgot the paper with the numbers at the garage) and as stated, it ran GREAT up until it didnt.
So, any thoughts? Im afraid that theres a crack or some internal damage to the carbs, or at least the left. I havent been able to find one just yet.
Theres a chance that I may just go ahead with some top end work come spring anyhow, but dammit I want this bike running correctly when I put it away for winter here shortly. Im still a HUGE newbie when the two strokes are involved, so any help would be appreciated.
Thans in advace folks.
-Mike
-Mike
