RD400C forks?
welcome to the thread...
off head, no. but it should be easy enough to go over to bike bandit and see what other bikes use the same bearings as your bike. if you want inverted forks, you may have a harder time, but it can still be done if you find a set of triple trees that have the correct steerer tube length. if you measure the outside and inside diameter, you can find a bearing to fit that space pretty easily.
