Re: 1982 Gpz550 - Grid Rocket - Slangin that powder.
Slowed down a bit for a while, monies been tight, works been hard to come by but I've made a few updates and design changes along the way [for the better], I found my power loss problem which turned out to be a bad ring in cylinder 1, on top of a now cross threaded #2 plug :-\.
Anyway, I patched up the ding in my tank from the fall in my pickup bed, I ended up pulling the top end from the base up to replace all the gaskets and go through everything more in depth, I checked my valve clearances and got everything within spec, I still need to pull my valves I figure I might as well replace the springs while I'm in there and check everything out since I'm powder coating all the engine parts anyway. I really dont want to dont want to have to dig in there again lol.
I pulled my wheel and steering bearings to replace them all when I can afford to drop the dough, everything was pretty rough anyway. Melted my starter relay from excessive starting during a new years day ride so that needs to be replaced now.
I got my new progressive fork springs in and replaced the seals, not totally happy with the squish just yet, so I'll have to play with them a bit more to stiffen it up a little more to my liking, they have to get pulled apart again anyway to coat.
I'm on the lookout for a matching adjustable set of clutch lever and brake master cylinder that looks good and isnt to hard on the wallet, the master I was given leaks, but once I manage that I have some braided brake lines I fully intend to buy in black or blue.
Lets see, aside from that I've just cleaned up the wiring harness and frame, gotten rid of most unused tabs and mounting brackets, over the next few days I plan to weld up a rear mounting tab for the tank thats hidden under the seat and get my frame 100% ready to powder, make a few changes to the seat and extended it so its formed into the tank.
HOWEVER! I have many parts sand blasted and ready for powder, a solid plan and some good ideas I cant wait to try ;D I do have a few pics of the progress, its finally taking shape and starting to become a reality, which makes me feel all warm and tingly inside, kind of like that first cut into a fresh piece of construction paper.. mmm.. you all know what I'm talkin about! haha
By the way, LOVE these Pirelli Sport Demons.
Still want and plan to get a new rear shock, looking at options as I'd like to get a stiffer ride.
Okay, now... try to follow me here, I'm thinking of going with this symbol on my tank sides, it's the japanese symbol for "light" and, what I intend to do is, paint the tank black, cut this design out of electroluminescent sheeting, apply it to the tank, spray a super thinned coat of paint over it, and clear coat...many many times. In theory, the design wont be seen when off but at night, when turned on will glow through the paint in a nice cool blue to go with the Tron theme of the bike.
Possibly also a double "glowing" stripes as well down the top of the tank, if it works out. This stuff isnt cheap so, some testing needs to be done first.
This kind of helped, but after I found the compression loss, I may not need any exhaust reduction, all I did was weld the stock reducer at the end of the pipe and slip the "can" on over top of it, it changed the sound to a more bubbly dirt bike sound that I dont care for, if the new piston rings fix the issue and this isnt needed, I'm ditching it entirely, I love the incredible growl this thing billows out the open pipes.
This is how the motor sits currently, no, thats not a new starter
I just lightly hit it with the sand blaster to make it look new and me feel better lol
After a lot of disassembly and media blasting parts.
I actually started on my rims today, I figure get them out of the way while I'm already working on customers parts, at least they can serve as demo pieces until I get a rolling chassis.
The powder coat I'm using for those who are interested, is "Blue Starlight" a metallic transparent, and "Super Durable Wet Black" Which is the highest gloss level black, like a mirror I could find, all from "powder by the pound"
I'm doing a 2 tone scheme on my wheels, blue lips and the center outer facing blades of the spokes, and black on the rest, but I'm also doing a clearcoat for mar protection, and the last coat of clear I'm going to mix in a powder "glow additive" and do only the lip of the rim to hopefully get the signature tron look on the wheels, my plan is - if it works out - to mount some hidden 5mm UV leds facing directly at them so the glow stuff would always be fully charged while rolling, it's clear when off so it shouldnt change the appearance during the day time.
Anyway, I only managed to get the blue coat on my wheels today and mask them for the black coat, I'll be spraying black first thing in the morning and cant wait to see the result.
I did a small scale test and did a coat on my upper tripple, let me just say... this stuff is ridiculous in the sunlight!!!
That's all for now. More to come soon. 8)
