Re doing a Honda cl350- Electrical
Nykindaguy
Hi everyone,
I am requesting some help being that i am new to these tyes of bike. I have a 1969 onda cl350 and i am trying to get it up and running the right way. The old wiring harness was pretty cut up and mangled so i trying to sort out what they did and understand how the electrical works on this bike. As of right now i have the the brake and turn signals working. the neutral light doesnt seem to be getting power, its not just the light not turning on i have ohned it out. And yes it in neutral. Is there a way to test just the indicator and the switch?
Now my next question.
My headlight doent want to work. No power going from the switch in the bars to the light. But i have power to the switch. I have made up my mind that i am going to use a switch simply on the headlight for that light and remove the switch on the bars. So the question is can some one explain what the yellow and yellow/white wires going to the handle bar switch are for?
Also correct me if im wrong, cause i probably am, in order to use another switch i am going to pull power from the black wire going to the original switch and connect it to the new switch, then from the swithc to the white on the head light. and to use the idiot light on the dash i just have to connect it to the headlight side of the switch so the light turns on whe i turn the switch is in the on possition.
Any help would be great, im sorry if these are simple questions but like i said not really familiar with these older bikes.
