Re: Gauge Faces / Speedo Tach Decals - Now for DanMoto/Acewell gauges
For the CB750. This is for a 77 Super Sport, so not sure about how it fits the earlier faces, but I can easily adjust it for other years.
Another CB750 version with a "Metallic" treatment. (does not print with metallic ink)
Final CB / CL350 design for now. These are all going to the printer tomorrow. If you have a request, get it in now. Won't be printing another batch till July-ish.
This is a stupid question, probably, but I took apart the gauges, and had a couple of questions.
1. How do you take off the tripmeter knob so that you can pull the cover off?
2. How do you pull the needle off so that you can get the overlay cleanly on?
BTW, this is a 1976 Honda CB360T.
There is a small screw (that is probably rusted to hell) in the end of the tripmeter knob. Drill that out and the knob will slide off.
The needle can be removed with two spoons, of go to Home Depot and buy this AWESOME tool.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100034526&R=100034526
I'm looking to find a replacement screw for that little bitch BTW. I'll let you know if i do.
I think the c360T should be the same as the other 360's. I don't cut or print the milage cutouts so you can make sure they are perfect to you faces.
here is a blue that's just about as close as I can get it...dang it's hard matching this color...it's metallic for one, and the picture has too many highlights
and with the CB360T in there...
So you just essentially pry the needle off, and it pops out?
Thanks for the info, and the gauges are fantastic. Love the newest ones, the designs are killer.
I found that a normal kitchen fork works great to get the needle off.
When you did the guage stickers.. Did you use two different fonts for the "mph" and the "x1000 rpm"? Same question for the "Nippon Seiki"..?
it's all the same font. Helvetica Nue. Just different type settings/weights/caps/kernings etc.
I'm not in the money for a set of these nor am I at that stage of my build. But, when I am, I will keep you in mind. Thanks
sure. you would need to send me your faces as i havent done a CB550 yet and i'd have to scan & measure them. Just sent a set to the printer. I won't send another set off until late June/Early July.
