I was just wondering if anyone has rejetted their Honda 360? If so, what breather/exhaust are you running and what jets are you using? Thanks in advanced for any tips or help. Troy
Hey Pj I just found a post where you gave the link to the 'rule of thumbs' here in case some else may need it: http://www.motorcyclecarbs.com/Jetting_Rules_of_Thumb_W43C551.cfm
Anyhow, looks like I should try 71 for the main as a starting point and go down and 35 for the slow??
Well, after doing more reading it seems that I should wait on rejetting until I get some problems worked out. Today it was fouling plugs like crazy and would only run while choked. It would only start with the starter and not the kick. And I could only get it to run a few minutes at a time. I notice one of the floats was not working properly as fuel was pouring out of one of the overflow tubes. It was a problem that I thought I had fixed before I started modifying the bike. I plan to check the floats and re set them. I'll put the carbs back on and see what happens.
Thank you very much PJ. good to know! Today I think sorted out the float problem. Seems the PO put new floats in but didn't adjust them. They were sitting at 1.125 . I took them to 0.75 and it made a world of difference. Didn't have time to mess with it too much today but plan on working on it tomorrow. I'm putting the clear on the tank today so tomorrow I should be able to gas it up. That should make it much easier to work on. I also believe that the carbs need to be synch so I'll have to try to do that as well. Hopefully I can take it on a test ride and do a plug check. Again, Thanks for all the help. Troy
