really crazy idea
rockcitycafe
I make things.
here's a really crazy idea
when I was playing with cam timing, I was amazed how I could develop huge torque on my 360 at low rpm by advancing a couple degrees, top end was pretty bad though, but the bike would pull your arms out from idle
when I put the cam back to stock timing, top end came back but low end was more mild
here's the idea, anyone think of putting an idler sprocket on the front of the cam chain that is moved by hydraulics or servo action that would take up the cam chain in the front and advance the cam, or retard it, based on rpm, to keep the engine making good torque over more of the rpm range? probably not as useful for a race bike, but might be a neat mod for a street bike
First thought is Rocan would be real excited by this, second is if anyone should attempt this it should be you. I'm sure you have plenty of other work going on in the shop though. Variable valve timing is great. Id assume amperage to run servo would over tax electrical system, and not sure these bike have enough oil pressure/flow to use oil pump to power hydraulically. Anything is possible with enough ingenuity. Most people would read your post and think of all the "problems" with the idea. I read it and think there is plenty of solutions that have yet to be found....
You could always use vacuum to advance/retard the spark. Dodge did it in the 80's, as did almost everyone else before EFI and VTEC/VVTi came along.
He is referring to cam timing not ignition. Controlling spark in relation to crank rotation due to piston speed is a necessity. The higher the rpm the less time you have for combustion to occur so the process has to be started sooner. Being able to control cam timing is a lot more difficult.
did some research and Porsche came up with a system like this for their dohc motors, which increased the valve overlap at higher rpms... seems like the concept is sound, the engineering to make it reliable might be a bit complex
nothing that complicated... I'm basically looking at redesigning the tensioning system to allow more slack in the front portion of the chain as rpm goes up, that in itself will be complex enough... it's still a thought though, I've got enough projects that I should focus more on, like bikes in the shop I could build and sell ::)
