Rear sets and front end conversion gsx 250
Brenden_gra
Hi guys,
I own a 1983 gsx 250. I am half way through building a cafe racer. Looking to swap out the front end including the triple tree. I want something with a bit more strength. Maybe even an upside down conversion could be cool. Any help or suggestions would be great as I am alittle lost with this.
Also do you know where I can buy pre made rearsets for my bike. Having trouble with this one.
any help would be great.
B
Have a look here:
http://www.dotheton.com/forum/index.php?topic=20951.0
That will give you what other bikes run the same head bearings (or go to All Balls Racing - they have a conversion calculator). Upside down forks would be way too stiff on your 250. GS550 is probably not a bad choice, if any.
No one makes pre-made rearsets for your bike. If you still have the muffler hangers / pillion footpeg plates you could drill a hole in them and mount Tarozzi footpegs. You'll need to fab up your own linkages though.
Thanks heaps. I will look into it. I wasn't really thinking about the suspension being too stiff with the upside downs so thanks for the advice.
What about a flat machined top triple tree clamp? Anyone with ideas? I want a flat basic surface as I have clip ons.
Thanks again
You can take your existing top clamp to an engineering shop and have the handlebar mounts welded up / filled from underneath. Then grind them off flat.
Again, no one makes custom parts like this for your bike....except for you ;)
