rear wheel sprocket changing
snielsen85
How exactly do i get the circlip off? do i need the tool or could i use something else and also i broke one of the locking tabs where can i get new ones and could i just use individual locking tabs/washers instead?
also if i get new brake shoes how important is it to get new springs with it? its the difference between spending 18 bucks and 40 bucks. If its a good idea to get new springs ill get the kit.
Yes, its better to use circlip pliers. You could try a few screwdrivers, but you'll scratch stuff and stab yourself in the hand etc.
Get a cheap pair, or kit, of circlip pliers, no doubt you'll use them again sometime.
Any fastener place will have washers with little locking tabs on them. Instead of using the original half moon things, just replace both with 4 locking tab washers.
In regards to brakes, the springs won't loose their tension much, they may eventually break though. Its your call, if the bike hasn't been left in the weather all its life, you may be right. But if the springs are a little worse for wear, change em.
One thing I don't skimp on is wheel bearings & brakes etc. Anything that can kill me basically.
Cheers.
I really love this website. Everyone has such great advice. Thanks to everyone helping me out. Hopefully i will have her running better than ever soon. Then will come the mods
Yep, this site is a goldmine for info. The members here are always more than helpful.
I have solved sooooooo many isues due to the right advice from members here.
Cheers.
If you buy new Vesrah brake shoes, they come with new springs. If your bike is a Honda, those sprocket nut tab locks are still available for around $2.00 each.
Do you know exactly where I can find those tab locks? I have looked on bike bandit and ebay and had no luck.
ok so i got the old rear sprocket off but the bolts are still connected to the old sprocket? Do i need new bolts? I assumed that they wouldnt be still connected. I dont know where to get new bolts
So you removed the circlip?? extracted the sprocket from the hub?the back side those bolts ::) should have 2 flat edges to anchor a wrench,apply a wrench and or a socket to the nut(s) and remove,,individual washers will not prevent the nut from backing off. You can reuse the original locking tabs,,,,,or blue locktite,,,or safety wire,,,,one last thing to remember when you install you new sprocket, lather the portion of that bolt(that goes into the hub) with anti seize compound
Still available at any Honda motorcycle dealer.
Part Number: 90522-286-000
WASHER, TONGUED (10MM) (Honda Code 0166405)
