Recommendations: electronic ignition for CL350
gomotomoto
Thinking about picking one up. Looking for pros and cons & trying to see if there's a specific product I should go with.
Fox,
a DYNA for a GL1000 will fit your 175 with very little modification. Remove one module and it fits straight in to that same space as your points plate. All you need is a spacer (tube) to slide over the advance-retard center post to make it the same diameter as the DYNA rotor.
We have done a few and they work well.
Watch ebay for a good price and you should do OK.
I have the Pamco and LOVE IT! Idles starts on the first kick, idles smoother, revs smoother, all around improvement for $109. Easy to install and pretty much set and forget. You'll need a timing light to fine tune it. I am putting these on every applicable bike now.
Have not gotten a reply from a few emails to this guy:
http://www.cb450ignition.com/Index350.htm
Possible he's away or really busy but need to make sure it's legit before I send him the money.
Anyone have info?
Can you give me an overview on how it works? Does it still use the stock advancer? Does it still need the condensor/cap? Is there an external module or is it all on the ignition plate? Is it simply an electronic switch (Hall Effect) to a high current transistor? For my first stage on my ignition, I was planning to just make a high current switch triggered by the points. I think this ignition is the same but using a Hall Effect in place of the points.
Single plate using the stock advance. Yes, hall effect type. Very much like a Dyna. Click the link to their site a few posts up for pictures and installation instructions.
